We buy the vehicles any way.For those that don't know, a water pump failure on that engine requires MAJOR
disassembly. Pulling the engine or taking the front of the vehicle off isn't shade tree
procedure.
Many brands have questionable engineering designs that may or may not cause
serious headaches if and when they fail.
My 2¢
He’s an interesting Tech - what’s the origin of his name ?Ford Tech Makuloco on youtube suggests the new Yellow Ford Coolant to help with the water pump issue. In fact he recommends it for all Ford Vehicles.
Drive the car to 50K then sell it. Or if you love it, fix it when it fails. Just start saving now.I ask because I have a Ford vehicle with the dreaded 3.5 Duratec V6 water pump.
Thing is, the higher the mileage goes on the car, the more anxious I get about the water pump failing. I'm at 11,800 miles now and I am deciding to go with the best full synthetic here on out there to do everything I can to help the water pump, not just Supertech. Yes, I am also flushing the coolant, I am about to do my first flush and will then do the flush annually for the rest of the car's life.
Not sure. Might be shark related. Truly enjoy his vids. He recommends mostly Ford lubricants, except motor oil. He is a Pennzoil Platinum guy. He thinks the GTL's hold up better in Turbo and GDI apps and recommends 5K OCI's with Motorcraft filters, for the proper bypass. The yellow coolant video is not too old so should be easy to find. See I found itHe’s an interesting Tech - what’s the origin of his name ?
Wrong engine. The Duratec 2.5/3.0L is a completely different animal. Those engines had the water pump located externally on the opposite side of the engine (flywheel side), driven by a tiny belt which ran off the front cam......“The Ford Duratec V6, also known as the MondeoV6, is an aluminum DOHC V6 engine with a 60° bank angle introduced in 1993 with the Ford Mondeo. The primary engineering input came from Porsche,[1] who was developing a similar V6 before selling the engineering to Ford, and Cosworth, who helped with cylinder head manufacturing.[2] The Jaguar AJ-V6 engine is similar but adds variable valve timing.”
Care to elaborate?Minor coolant contamination is a major deal with synthetic oil. Not so major a deal with conventional oil.
