207.8342 degrees F
I don't have an ECO mode unless the normal mode is an ECO mode which is likely. Leaner running engine runs hotter but with better fuel economy.I wondered how much cooler the oil would be in Sport Mode. 30 degrees is significant! I run mine in Sport at times that I'm heavy-footed, I figure when it's using its entire 300 horses its not a bad idea to let it run a little cooler. But usually I tool around in the Mid-mode. I understand the most economical mode allows for hotter temps...any idea how much hotter in ECO compared to the Middle selection? Thanks!
Yep, it will do it there. Ran 265f on Atlas.My 2024 crosstrek has hit 237 degrees with 0w20 in February climbing Ike’s gauntlet..
My BMW will run coolant at 117c on hwy. on track, 78-80c.I wondered how much cooler the oil would be in Sport Mode. 30 degrees is significant! I run mine in Sport at times that I'm heavy-footed, I figure when it's using its entire 300 horses its not a bad idea to let it run a little cooler. But usually I tool around in the Mid-mode. I understand the most economical mode allows for hotter temps...any idea how much hotter in ECO compared to the Middle selection? Thanks!
What is considered as 'Optimal' engine oil temperature... ?
We have several different petrol cars ( VW/Audi/Skoda ) in the family
where the current oil temperature can be read via the on-board computer.
I see that there is quite a large temperature difference between the cars oil temperature
when they are driven on the same road and the same distance under the same conditions.
Is there an optimum oil temperature range for a fully synthetic engine oil
when it works best and the properties of the oil work/perform at their best ?![]()
Dumb question - isn’t the oil a pressurized system? That would mean 212F is no longer the boiling point of water, no?It'll vary quite a bit between different engines, uses, and oils. A fellow racer drives his twin turbo Mustang all over the country. A few times a year, he drives it 1000+ miles, runs mid-8s 1/4 mile all week, and then 1000+ miles home. Cruising at 70-75 mph and 2200-2500 rpm, his sump temp is ~260°F in the summer with HPL BAS 10W-50.
The doubled rate of degradation every 10°C statement isn't entirely true for engine oils. The exposure to blow-by gases, fuel and water dilution, and ambient air conditions skew that significantly. Burning 1 gallon of gasoline produces 1.033 gallons of water. (C8H18 + O2 = CO2 + H2O) That water is going somewhere. Just because water is a vapor doesn't mean it won't enter the crankcase and condense in the cooler sump, especially after the engine has been shut off. Hence, I like full operating temp to be above water's boiling point (212°F) and the 50% distillation point of pump gasoline (195-210°F).
Also, all that oil in the pan isn’t under any pressure at all.Dumb question - isn’t the oil a pressurized system? That would mean 212F is no longer the boiling point of water, no?
Edit: I thought about it some more and we are talking engine oil temperature at a single point. It’s much hotter in the combustion chamber and the water is just boiled off and goes through the exhaust. I’m still new to all of this.
Well, water doesn't need to be boiling to evaporate, so, you don't have to hit 100C to remove the water.Dumb question - isn’t the oil a pressurized system? That would mean 212F is no longer the boiling point of water, no?
So, you’re advocating for higher oil temperatures as being optimum?You don't want water to condense into the oil to begin with, not even momentarily. Emulsified water, in just 0.1-0.25% concentration, can compromise MOFT. In localized high heat and pressure areas, the water can flash-vaporize resulting in erosive wear. The water can also breakdown into its constituents and adhere to the surface. (see: hydrogen embrittlement) As far as the oil goes, oxidation increases substantially at even very low concentrated dissolved states of <600 ppm. ZDDP, your primary anti-wear additive, is a phosphate ester which readily hydrolyzes in water, greatly reducing its effectiveness and promoting acidic growth. This is why it's very common to see a multiplicative increase in wear as oil temperature drops. (aside from additive response) Certain EP and AO additives are also readily hydrolyzed in water.
Thus, I don't want to wait for water to evaporate at a lower temperature. When water enters the crankcase as a vapor, it needs to leave as a vapor without any chance to condense, emulsify, or dissolve.
What is considered as 'Optimal' engine oil temperature?
What range would you suggest, then?
Short answer to the original question:
100c (212F) is the optimal operating temperature for your motor oil.
What course are you on.....?255 (shall i convert for the Farenheitily-challenged?) here on a cool down lap.
VIRginia International Raceway.What course are you on.....?
Man I would love to live near one...
