The instrument cluster allows me to monitor the exact coolant temperature. When driving around town, it oscillates betw. 90-96 deg. C. But when I drive fast on the hwy, it drops down to 80C. Is this considered "normal"?
The actual coolant temp gauge doesn't budge, but that's because it is programmed to stay in the same spot within a certain range of temps (75C-113C, from what I've read).
The reason I ask is that recently I noticed poorer hwy MPG (about 27 vs 30 previously). In addition, excessive moisture was detected in my recent UOA sample. I thought that maybe my thermostat was stuck open, not allowing the engine to operate at an optimum temp. I replaced the thermostat, but it made no difference. So, what else would you recommend I check?
One other possibility is the CCV system, mainly the oil separator valve. But from what I've read, if it was clogged, the engine would exhibit rough idle. Mine doesn't.
FYI, this is the 3-liter in-line six (M54) engine with 42k miles.
Thanks.
Thanks.
