Hi,
Lubricants Brand loyalty
As an Engineering Trainee with BMC in NZ in the 1950s I was educated on Castrol by Castrol for BMC cars and then on Caltex products by Caltex for use in a wider environment
We used Castrolite (20w-20), Castrol XL (20-30) and Castrol XXL (30-40) in all BMC applications – MG, Riley, Vanden-Plas, Austin, Morris, and Austin Healey etc.
Then along came the Austin-Morris 850-Mini! Duckhams developed the 20w-50 viscosity product especially for this application. I initially used Castrol XL and XXL in the export CKD prototype in NZ as 20w-50 was unavailable in advance of the car’s introduction and it simply leaked and burned it fiercely!! Permanent shear was the culprit as a number of internal components failed too on the lower viscosity lubricants and the high oil temperatures encountered.
I always saw 20w-50 as a “cure-all” lubricant for bad engine design!
A couple of years in Europe with BMC kept the Castrol and Duckhams flames burning bright!!!
On return to NZ from Europe I was quickly educated on the abilities of the Commercial HDEOs of the period – Shell, Caltex, Castrol and Mobil! Durability and engine cleanliness was the requirement and CAT specified lubricants performed best!
Castrol was the worst performer; the others were about on par
On return to Europe (early 1960s) and when working for Chevron-Caltex in Denmark I became very interested in the lubricant Standards of the era. CAT and Mercedes Benz did their homework – and so did VW & Porsche, HD oils (HDEOs) were the “trick”. Those formulated to CAT’s Supplement 3 standard worked best. So I rapidly became aware that the best HDEOs outperformed the PCMOs by a large margin, especially in cleanliness and durability during normal OCIs.
ML MM MS and DL DM DS were the API’s Standards then. The HDEO and PCMO standards were pretty much determined by the Oil Companies via the API and vehicle Manufacturers had very little say – except those noted above
I worked closely with Shell in the 1970s and used their synthetic gear oils. Later I used their synthetic engine oils, Shell makes excellent lubricants and they have a long and stable history. The first ever synthetic FF was Shell’s XMO 5w-40 in Porsche’s V8 928 in 1992! How the World has changed!
I used Castrol’s Formula R 15w-50 (German sourced) synthetic from about 1974-5 and over the next decade or so assisted in developing this lubricant (progressing to TWS 10w-60) in a wide variety of applications and engine types – both petrol and high speed diesels. It was and still is a great lubricant(s) now in two versions) in the correct application. At the Nurburgring 24Hr in 2011 I was informed by Castrol’s Engineers that the Engineering Staff who developed this product along with their excellent synthetic ATF (Transmax Z – for Voith, MB and ZF applications) have all passed on.
They certainly left an enduring legacy in these great products!!
Over the next few decades lubricants formed a huge part of my daily regime – mainly field testing.
I worked with Castrol and Mobil on advanced HDEOs – 15w40 semi synthetics with Castrol and Delvac 1 5w-40 with Mobil. I used and tested a wide variety of Brands during this period and briefly used Ore-Lube’s synthetics at that time as well – about 1975!.
I used HD lubricants or early synthetics in all my petrol engines up until about 1995. From that point on I’ve used synthetics in everything I own. I always seek the longest economic OCI!
Castrol (and I) had a series of bad experiences with the original ester based (green) Castrol Formula SLX 0w30 around 1997-8. It was quickly withdrawn from sale however later versions (SL>) were fine!
So, whilst I used many Brands over time my specific loyalty has lasted for some decades and Castrol, Mobil and Shell still live happily in my equipment – and most are available from the local discount suppliers too
