- Joined
- Sep 28, 2002
- Messages
- 39,799
The technique he's describing is the same theory as the MMO "inverse oiler" worked with. This would work. You merely have to assure that you maintain the water supply and, as you asserted, regulate the flow. The Marvel Mystery Oil inverse oilers went out of vogue ..but were still available to order in the late 70s (I dunno beyond that). They also required being filled every 500 miles. The expense they added to operations was not worth the gains.
The PCV valve is effectively a "manifold leak regulator" ..above a certain Hg ..it's open ..below it's closed. The hose behind it still sees full manifold vacuum.
For the "normal" method.
I still find the PCV hose the most convenient way to do this for those who have a centrally located PCV port. I also think it is much easier if you get a longer hose and allow yourself to regulate the throttle with your foot and using both hands. You can then just put the longer hose into a large jug of water and keep the engine running. The faster the engine runs ..the more water will be drawn in. ..and further more... I also think that this is most effective under load. For those of you willing to go through this ...you merely route the longer hose throgh the cowl and into the passenger compartment ..get going about 60 ..and shove it in the jug (you probably will need a copilot). I've done this many times with both water and ATF ..atf being my purge of choice simply because you don't stiffle the combustion process and it cleans spledidly. It also produces a massive white cloud that military smoke screans would be envious of.
Apparently they are still manufactured ..the "inverse oiler".
