How about this. I have a friend who is considering doing a decarbon with my help. If he gives me the go ahead, I will do a test. Cant really get scientific with it, aside from this
As far as he and I know, the car has never had a FI cleaner, and has always been filled up at the cheap gas station
First, use 3 500ml bottle of filtered water(can’t get distilled water here that I know of), and put a piece of paper behind the tailpipe.
Use the basketball nozzle and suck up 500 mls of water
Then, move up to the vacuum line connector that came with the vacuum pump that I got mailed in from the states (about half the size of the hose), then
Last, unadulterated water through the hose that I have. It’s big enough to flood a 2L v-6 engine, because I did it twice the first time I did it to my car.
I used the full flow before I did the BB nozzle.
Leave about a minute or two of free running between them to make sure that everything that will flow out has flowed out.
Change the paper when a different nozzle is used.
Only problem I see is that the steam will start breaking stuff up, and it will be easier for the second and third sessions to break stuff up because it has already started breaking stuff up.
I think honestly that more water will do more, but I think at a certain point the water is stifling the combustion of the fuel, like I referred to in my last post. If the spark can’t carry throughout the CC, then I don’t see al the fuel being burned.
If he won’t let me, then I will do another run on my car, and see what happens with the same test. I don’t feel like I got everything out of there, so it doesn’t hurt my feelings to do it again on my car.
