Indeed, much uncertainty with this kind of screwup. No it's not a mistake, it's lazyness and/or stupidity.I’m not one who handles uncertainty very well….![]()
This is what I would be most concerned about. Turbos operate at insane RPM's and temperatures. And they're certainly not the cheapest part to replace.......Embedded particles in the bearing material are going to continue to wear against the hard steel of the journal. Turbo chargers are particularly susceptible to this because of the small size of the bearing and the extreme RPM at which they operate.....
Yep. And the turbo charger in this model is fairly rare, it’s significantly larger than on the regular turbo models of the vintage.This is what I would be most concerned about. Turbos operate at insane RPM's and temperatures. And they're certainly not the cheapest part to replace.
Yeah on my diesel truck a fleck of casting sand probably or a metal shaving took out my he351ve turbo. So then I found a 6 micron absolute 6655566 hydraulic filter I added that to the turbo oil feed line. It filters about 1qt per minute at idle and 3qt per minute on the highway. The little 6655566 lasts about 5,000 miles, I'm usually changing the oil around 3,000 to 4,000 miles.This is what I would be most concerned about. Turbos operate at insane RPM's and temperatures. And they're certainly not the cheapest part to replace.
Yes. If fire up the grinder and use it with my cheap little pm2.5 meter down wind it will pickup grinder dust.
On a cold start the oil filter maybe bypassing oil.
The filters have ratings for different size particles, a decent paper filter will stop something like 90% of 2 micron, 95% of 10 micron particles and 99.9% of 27 micron. So as long as the oil filter didn't bypass when the engine cold started the filter would have caught pretty much everything. But we don't know.
I lost all respect for him when he had a TDI in his shop. He even stated on camera this isn't probably the right oil (some 5W30) but that's what the customer wants.. He's a good diagnostic mechanic but a hack otherwise in my book. You are correct though, for the money what would you expect.This could have been a Rainman Ray job. Work like this is more common than you want to know. Time is money and mechanics aren't paid the greatest. Best of luck but the law requires you to have a monetary damage. You can't sue for a potential problem. Maybe the dealer will do some good faith work if you're lucky. Dealers aren't exactly getting rich lately though.
My bad I'm thinking in hydraulic filters again.View attachment 183001
Purolator Boss and WIX XP both show ~25% at 15 microns.
A lot of good information there. But I think this is pushing it a bit.......
So many variables there. What grade are they talking (red/coarse, blue/medium etc) and by hand or with a power tool? If the latter, what's the surface speed of the disc?A lot of good information there. But I think this is pushing it a bit.......
"It takes about 15♦seconds to remove 0.203♦mm (0.008♦in) of metal with an abrasive pad".
With a grinding disk, even that is a lot. With a Scotchbrite pad, that much removal that fast is highly unlikely. But it doesn't change the fact they can contaminate the internals with fly off abrasive particles that quick.
He's entertaining sometimes. I have seen him using some abrasive attachment to clean up intake gaskets. Also loves the brake clean. If every mechanic was on video you would see this all the time.I lost all respect for him when he had a TDI in his shop. He even stated on camera this isn't probably the right oil (some 5W30) but that's what the customer wants.. He's a good diagnostic mechanic but a hack otherwise in my book. You are correct though, for the money what would you expect.
This thread just hurts me as @Astro14 cares for all his Volvos meticulously.
That's way more scary than I needed to hear.He's entertaining sometimes. I have seen him using some abrasive attachment to clean up intake gaskets. Also loves the brake clean. If every mechanic was on video you would see this all the time.
Exactly. Using an abrasive disc on the pan, while not preferred, is usually fine if the tech runs the entire pan thru the parts washer.The pan has nothing to do with this, they probably did run it through the parts washer. It's the fact they used it on the block! They can't run that through the parts washer.
I have friends who ask me why I chose to be a desk jockey vs. following a passion(cars) and turning wrenches. I saw too much shop politics, management trying to pad the bottom line and earn a promotion and a general attitude of send it, get paid and don’t care with the techs when I was a porter/detailer at the local Honda dealer.lets face facts, no one with a lick of sense would want to be a mechanic at a car dealership... flat rate, tight warranty labor rates, supply your own tools, spend your life bent over... get second guessed by everyone.... so nah... so the dealer will train the guy that used to wash cars to change oil, and if the guy who used to wash cars and now changes oil can do that without too many problems, they try to turn him into a technician... ,
just the way it is.
