The white blocks, particularly the older ones, run better on a heavier weight due to the ring pack design. It was revised in '99 to better accommodate the lighter oils, but it's still a 20 year old engine design.
It will run on a 30 weight, and in fact a 30 weight improves turbo spool up. Most dealers in the Northeast are pumping 5w-30 into them (because it's cheap). It won't hurt the engine. But consumption trends up. On the older white blocks before the revision, it goes up a lot.
The big reason people lean towards the lighter weights in these is fuel economy. In a fleet/commercial context, the fuel savings adds up. But on a car driven 1,500 mi/year . . . who cares?
No way, no how, do you run a 20 in a white block. Anyone recommending a 20 just doesn't understand this particular engine. It's not a recommended weight, and no dealer or indy will ever put that into one if given a choice. Any more than you'd pour it into a BMW that needs a 60. Still don't believe me? Check the manuals, call a few dealers, and then ask a couple indys. They'll all start at a 30.
I prefer a 5w-40 in the NA because they are not speed demons to begin with, consumption falls to nil, and the engine is better protected. I still get mileage in the very high 20s. I'll lean towards a very heavy 30 in the turbos (GC for instance), but balance that against spool up.
Castrol is just a cross-marketing plug. You can run a variety of oil brands in these, and they all more or less work well if the spec and weight measure up.
