Make sure she runs premium as well. I suggest 0W-30.Very interesting report! My wife has a 2022 CRV 1.5T and while I haven't sent in a sample for it yet myself, your report helps confirm my theory on OCI's for these little motors. I change at 4k miles with any brand full syn and an orange can because the fuel dilution is just so bad on these engines. We've had other DI motors and I've never had one that smells so strongly of fuel on the dipstick or oil.
These things take so little oil anyway that it's not expensive to just replace early and often anyway.
Make she runs premium as well. I suggest 0W-30.
You better watch the fuel big time. Especially on hills with turbo......knock detect will go super rich very rapidly.We do still use 87 octane, but we're in Colorado where that's midgrade. I did run 91 octane for a few cycles and honestly couldn't notice much of a difference and up here anyway the price difference is big enough to be annoying lol. We do have ethanol free options so I do wonder about that...
You may not "feel" much difference, and that I suppose is the fuel management trim doing the job, but you don't feel the fuel going into the crankcase.
Define "requires". Sure, that's what Honda will tell you.Correct me if I'm wrong, but I believe this motor requires 87 octane (min), not premium 91/93?
No one really wants to address WHY this engine fuel dilutes so badly.
It's pretty simple, the effective full boost CR is sky high. If the engine knock sensors (they are quite keen) detect even the slightest knock, fuel enrichment becomes fairly aggressive. Running higher AKI fuel, can help (still not perfect)
"or higher" is better. I noticed pretty quickly when I started using 91 octane that the oil level no longer rose on the dipstick as I got into my OCI. It does seem to be worse on this Honda engine than on other direct injection engines. It is what it is. I'm using 91 octane for the rest of this car's life.Honda says 87 octane or higher. There are lots of other 1.4/1.5 TGDI engines with similar power output that don’t have this dilution reputation. I’d think they would enrich similarly.
I believe Honda is pretty agressive on the enrichment, my main evidence is improved MPG with 91-92, in particular, Shell. A statistical difference with Shell Premium.Honda says 87 octane or higher. There are lots of other 1.4/1.5 TGDI engines with similar power output that don’t have this dilution reputation. I’d think they would enrich similarly.
I would just leave it on, then just replace every second oil changeI do leave it on for two OCI. I just twist it off, empty it and twist it back on. It's very easy to reach on this car and the sure grip they use makes it easy to remove without damaging the can.
Well, I’ll take your word for it. That looks like standard Asian filter media fuzz to me, and every one I have ever replaced was dry. No Honda though.Yes. If you feel the surface of a new filter it feels slightly oily. More of a spray-on oiliness
It's easy to do and it makes me feel like there's a more complete exchange of fluids. Plus, it seems like a lot more than .2 qt comes out. Not necessarily from the filter itself, but from above the filter. It starts pouring out as I loosen the filter, then when I get it off and flip it over, even more comes out.Right. With the ADBV just inverting the filter doesn’t drain much oil anyway. Plus the entire filter only holds .2 quarts.
There is a major class action lawsuit against Honda with this engine.Wow these little Honda engines are terror on these oils
I wouldn’t run 87 in anything with a turbo. Remember under boost conditions, you are increasing compression tremendously. I have a 2020 RDX with the De-tuned Type R 2.0L. Yes. Fuel door says unleaded only. Premium recommended. Run 87. Loose 3-4mpg and you feel it being further de-tuned and pulling timing out.Correct me if I'm wrong, but I believe this motor requires 87 octane (min), not premium 91/93?
Do not go over 5,000 mile OCI. don’t waste time on the oil life monitor.I forgot to mention, and it's too late to edit the first post:
The Oil Life Monitor on this oil change was at 15%
Yeah, I'm aware this is a low mileage OCI situation. I was just listing the OLM for completeness. Many times people are curious what the OLM read when the sample was taken.Do not go over 5,000 mile OCI. don’t waste time on the oil life monitor.
All engines 5,000 max.Yeah, I'm aware this is a low mileage OCI situation. I was just listing the OLM for completeness. Many times people are curious what the OLM read when the sample was taken.
