Quote:
Quote:
Dino oils couldn't even keep my brother's 05' Corolla engine clean with oil changes every 4k-5k miles. It now has twenty some thousand miles on it. I looked at it last weekend. Varnished dipstick and it has built up black deposits in the oil fill hole (I assume it's oxidized oil with carbon particles in it).
His 1st Gen. Prius engine is quite sludged and varnished up. He bought it used this way.
My mother's 99' BMW 328i is also quite sludged up.
I've seen people's clean engines that used dino oils. I know it CAN keep engines clean. It just doesn't take much to go beyond what dino oils can handle.
Some synthetics were not able to keep my VW 1.8T engine clean during 4k-6k mile OCIs. Tougher job with tougher oils but still not tough enough. Only certain synthetics are able to keep it clean with those OCIs.
Quote:
I think the point of the "cheapest oil" doesn't automatically translate to "inferior" when we're talking about non-turbo, lo-pop, mid-horsepower offerings in the econobox sedans and family cars. That would include sub-280HP V-6s, and most non-turbo 4banger DOHC American, Japanese and Korean engines, which together probably comprise 90% of the engines owned by folks here on BITOG, and more than that out on the street.
Well, after I posted that folks come back with pics of varnished Saab turbos and stories of sludged VWs, and I deliberately left those out. Saabs and VW's are different, for whatever reason. They aren't venting the crankcase or there is a LOT of blowby, or they're very hot and hence, ought to run synthetic. A 2005 Toyota, sludged/varnished in 20k? Something's wrong with the PCV, it has to be. I help a friend with a 2003 with 100K on it replace his cam cover gasket and it was literally new under there, and he takes it to J-Lube every 5K fer cryin out loud. He's religious about it, but 5K is his OCI. I've got 40K on my Accent Hyundai 1.6 and it's like new, dipstick, cams, all that can be seen through the oil fill, half running dino, QS, Pennzoil, Havoline, half running PP. The Saab or VW with sludge? Nothing new. But a 2005 Toyota with varnish and sludge at 20 to 30K has mechanical issues and it ain't from running dino.
Utah Bill, you're a Toyota guy, is 20-30K on a Dino 4-5k OCI schedule cause for sludge and varnish, or is he not venting the crankcase?
