I just received a response from Valvoline regarding
part nr 811095 Synchromesh MTF
Here is the PDF
synchromesh_mtf_20130725193931
Valvoline SYNCHROMESH Manual Transmission Fluid is a high performance manual transmission lubricant designed to meet the extreme demands of passenger car manual transmission gearbox applications in certain GM and Chrysler vehicles. It contains a blend of multifunctional additives, a shear resistant viscosity modifier and premium quality base stocks. It is designed to provide excellent load carrying capacity, extreme pressure properties, anti-foam performance, corrosion protection and thermal stability protection as well as provide excellent cold temperature properties without altering synchronizer performance characteristics.
This product is recommended for Synchromesh applications in certain GM and Chrysler vehicles where synchronizer performance is vital. It is fully compatible with components in modern manual transmissions including yellow metals like bronze, copper and brass. Valvoline Synchromesh Manual Transmission Fluid is suitable for use in the following manual transmissions and manual transaxles: GM Part Numbers 12345349, 12377916, and 12345577, and Chrysler Part Number 4874464. Meets API GL-4.
The Valvoline SYNCHROMESH Manual Transmission Fluid Advantage
• Wide Temperature Range: Enhanced performance in both low and high temperature operating conditions
• Thermal Stability Resistance to oxidation and remains stable under extreme temperatures
• Wear Protection: Excellent wear protection under high loads and extreme pressure
• Anti-Foam Performance: Exceptional anti-foam performance for added protection
• Corrosion Protection: Protects parts from rust and corrosion
• Yellow Metal: Fully compatible with yellow metals including copper, bronze, brass
• Synchronizers: Outstanding performance of synchronizers
Test
Vis @ 100°C (cSt)
8.8
Vis @ 40°C (cSt)
49.9
Viscosity Index
157
Spec Gravity @ 60°F
0.872
Density (lbs/gal)
7.27
Flash COC (°C)
201
Pour Point (°C) , max
-42
Phosphorus, wt.%
0.14
Sulfur, wt.%
Zinc, wt%
.35
0.11Product Information
A PRODUCT OF THE VALVOLINE COMPANY A DIVISION OF ASHLAND INC.
VALVOLINE SYNCHROMESH MANUAL TRANSMISSION FLUID
For Certain GM and Chrysler Synchromesh Applications
NOTE! Valvoline Synchromesh MTF and Valvoline Professional Series MTF are NOT the same product!!!!!
They show a parts cross reference that concludes that this product (811095) IS a replacement for VW G052726A2 which is called a 75w-90 MTF.
My good judgement tells me that this fluid is WAY too thin for my VW application, but you could probably use it to top off if the unit was a bit low.
It's pretty obvious if you research the specs that the
other product mentioned
Valvoline Professional Series MTF is the CORRECT part for my application.
The question is where can the consumer buy it for DIY use?
