Running different OEM MTF’s in other make vehicles
So, I tried experimenting a couple of different OEM brand MTF’s/GL-4 gear oil, on a variety of different manual transmission-equipped cars. I think certain ones from Nissan and BMW, were fully synthetic by default, and also didn’t smell “funky”, so I assumed they were just fine to run. A bit more expensive compared to conventional Synchromesh formulas, with brands like Valvoline and Pennzoil.
I do recall the Honda/Acura crowd running AC Delco’s semi-synthetic “friction modified” version of their Synchromesh, as some sort of “miracle” trans fluid/gear oil… If I recall however, this actually led to more wear and tear, since it caused there to be more slippage between the synchronizers/blocking rings in the gearbox. I would see a fair amount of more metallic debris, when draining the trans fluid.
On that note, I also can’t recall if Honda’s OEM MTF was semi-synthetic or conventional, but I don’t think it was fully synthetic. It also reeks like the friction modified stuff that I had just mentioned, although Honda and Acura’s manual transmissions aren’t something unique, like Subaru’s shared transaxle design (requires GL-5 friction modified gear oil). Somewhere on here, I also read about an oil analysis stating that Honda/Acura MTF having more calcium than other gear oils/MTF’s?
I did run Honda/Acura OEM MTF in my 2010 Chevy Camaro SS, which has a factory Tremec TR-6060 manual trans (calls for ATF). I recall it shifting okay for a few days and then starting to notice a fairly quick decrease in shifting quality, so I drained it and refilled back up with full synthetic Triax GL-4 75w-80 MTF, which seemed to fix the issue.
Also, on that note, I have also ran GL-4+ (GL-4/5 compatible) gear oils in my fair share of manual trans-equipped vehicles, and have not noticed anything negative. I’ve ran Royal Purple’s Gear Max GL-4+ 75w-90, as well as Motul Gear 300 GL-4+ 75w-90 in some Honda manual transmissions, as well as the same Tremec TR-6060 I just mentioned above, for track driving and drag racing applications. I didn’t notice anything special, aside from increased viscosity/weight, which is an obvious hassle for cold start driving performance.
Never heard of issues with Honda/Acuras running GM's fluid and this was actually supported and recommended by Honda of America. They published a tech doc for dealer techs on using this.
I had a couple manual transmission Chrysler Crossfires that came from the Karmann factory with ATF+4 and shifted horribly. Owners manual recommended 5w-20 syn, but that was equally bad. Tried Amsoil, Ford XT-M5-QS and others to no avail. Finally landed with a MB semi-syn from a company named NeedsWings. Shifts were smooth and this fluid was recommended for MB SLKs.
Also had a Fiat Spider (Miata) and switched to the Ford fluid with great results.
Mola’s chart may help your search
Updated List of Manual Transmission Fluids May 30th
NOTE: This list is only a “summary” list of MTFs available in the MTF Lubricant Market and only available in US auto parts stores and US Import outlets. It is not an endorsement nor a critique of any one fluid, nor is it implied that any one fluid will cure problems in MTs that have design problems or those that have excessive wear. Viscosities listed are at 100C and rounded up.
A.These MTL fluids are closest to a Kinematic Viscosity of 6.X cSt@100C (About the same viscosity as Dexron VI ATF) and SAE 70 or so:
1. Castrol Syntrans FE 75W,
2. BMW (Pentosin) MTF-LT-3,
3. Honda MTII or MTF 2.
4. Ford FML-XT-11-QDC
5. Volvo Manual Transmission Fluid (6.4 cSt) [Recommended for: type M655-speed with 6-cyl. engine, M66, MTX75 and MMT6 and of the type M56, M58 and M59 from and including model year 1996. Meets Ford specification WSSM2C200-D2]
7. Redline MT-LV SAE Viscosity Grade 70W/75W Vis 6.5cst@100°C
8. HPL Manual Transmission Life 75W 6.3 cSt
B. The next higher viscosity MTF would be the 7.0 to 7.6 cSt@100C versions(SAE 70W75) (About the same viscosity as the original DexronIII/Merc)
1.Royal Purple's Synchromax
2. Ravenol MTF-2
3. Honda MTF
4. VW part number G052512A2
5. GM Manual Transmission and Transfer Case Fluid
6. BMW (Pentosin MTF 2) MTF-LT-1, 2 ,3
7. Tutelo (Petronus, Italy, Product Code 1402)
8. Penrite Pro Gear 70W75 (Australia)
9. FUCHS Titan Sintofluid FE 75W Manual Transmission Oil. GL-4 75W Gear Oil
10. Redline Power Steering Fluid R
11. RAVENOL STF
12. HPL Manual Transmission Life 75W75 7.1 cSt
C. The next higher viscosity MTL group is in the 8.0 cSt to 8.9 cSt Range would be:
1. Castrol Syntrans V FE (8.0cSt)
2. Redline DCTF Dual Clutch Transmission Fluid (8.1 cSt)
3, BG Synchroshift II (8.2 cSt)
4. Valvoline MTF Part Number 811095 8.8 cSt
5. RAVENOL PSA (8.9 cSt)
D. The next higher viscosity MTL group in the 9.0 to 9.5 cSt range is (SAE75W80):
1. Mopar Type MS-9417 MTL 9.0 cSt
2. Pennzoil Synchromesh 9.0 cSt
3. RAVENOL SSG 9.5 cSt
4. HPL Manual Transmission Life 75W80 9.4 cSt
E. The next group of MTL’s are in the 9.6 to 10.x cSt range (SAE75W80):
1. Redline MTL 75W80
2. Amsoil MTF (9.7 cSt)
3. GM Synchromesh Series
4. Volvo MTF 645
5. Fuchs TITAN SINTOFLUID SAE 75W-80 synthetic MTF (Carries a GL-5 rating as well)
6. Lodexol (Morris Lubricants) MTF
7. Motul MotylGear 75W-80 GL-4/GL-5
8. HPL Manual Transmission Life 75W80 9.4 cSt
F. The next higher viscosity MTL would be 11.5 to 12.0cSt and SAE 75W85:
1.Redline MT-85
2. HPL Manual Transmission Life 75W85 11.7 cSt
G. The next higher viscosity MTLs in the 14-17 cSt (SAE 75W90) range would be:
1. Amsoil MTG
2. Redline MT-90
3. Castrol Syntrans Multivehicle 75W-90
4. Castrol Syntrans Transaxle 75w-90
5. Ford XT-75W90-QGT (Carries a GL-5 rating as well)
6. Ford MOTORCRAFT® Full Synthetic Manual Transmission FluidXT-M5-QS
7. ACDelco 10-4059 GL-4 75W-90 Manual Transmission Fluid
8. RAVENOL TSG SAE 75W-9
9. LIQUIMOLY 75W-90 GL4
10. PENNZOIL 75W90 GL-4
11. Motul MotylGEAR 300 GL-4/GL-5
12. HPL Manual Transmission Life 75W90 16.8 cSt
Let me state again: Before changing an MTF in a vehicle, obtain an OEM fluid sample and post the analysis in Gear and Transmission Lube Analysis so we can attempt to match-up a fluid for you.
If you have a candidate fluid that you think may qualify for this list please send a VOA of that fluid to me via a PM. Thanks
I also forgot to add. The OEM Motorcraft (Ford) DCTF that is ran in the Getrag MT-82 manual trans, which comes on all 2011+ Ford Mustang GT’s, seemed to do pretty good in my Tremec TR-6060 on my 2010 Chevrolet Camaro SS manual trans/gearbox. I continued experimenting with other DCTF brands and noticed they were all rather pretty good, but nothing super exceptional. I do believe Redline was the most viscous, at around almost 9 cst (@100 C degrees).
I don’t think I’ve tried DCTF’s in other manual transmissions, but I feel like it MIGHT be safe to do so..? I probably wouldn’t run it if I wanted something with the protection of a GL-4 75w-85 or 75w-90 MTF/gear oil though. Also, if I recall correctly, the early 11-14 Ford Mustang GT’s called for an OEM Motorcraft manual transmission fluid additive. I believe BG MTF additive was also fairly common when that wasn’t available. The TSB’s stopped calling for that later on though.
2. Ravenol MTF-2
3. Honda MTF
11. RAVENOL STF
4. Volvo MTF 645
1.Redline MT-85
1. Amsoil MTG
2. Redline MT-90
I’ve kinda been wanting to experiment with the two different Triax GL-4 75w-80 MTF’s/gear oils. They have a Synergy Gear ‘MT’, which is what you’d expect for a typical manual gearbox calling for a GL-4 MTF; and then they also have Synergy Gear ‘SF’, which appears to be some other form of gear oil/MTF made for automated manual transmissions on heavy duty, semi trucks(?)
I have yet to try the Synergy Gear SF, but I figured it would act somewhat like a DCTF, since it goes through what regular GL-4 MTF/gear oil would go through, in a modern synchronized manual transmission/gearbox. The specifications say they’re for some Volvo and Mack heavy duty trucks, which use AMT’s (automated manual transmissions).
AMT’s seem to contain the same, if not exact, synchronizers/blocking rings that a standard manual transmission would have. I figured being electronically controlled, it would probably see much more stable and consistent wear and tear, as opposed to a traditional MT? I wonder if typical MTF could be ran in those AMT’s then… Looks like a chemical analysis might need to be done on those two MTF’s. I might read into the product data sheet and safety data sheet, to see if there’s anything significantly different between the two products.
I've been running the Motorcraft XT-M5-QS in a relative's old Nissan Sentra 5sp. I felt silly putting a $100 worth of gear oil in an old beater, but it was left over from a project that got cancelled. It hasn't blown up and shifts about the same as with anything else.
Seeing as how folks somehow get away with not changing manual transmission fluid for anywhere from 75-90k+ miles, I wouldn’t be surprised if you went 30-40k solid miles on that trans fluid, before maybe even considering changing it.
Is that Motorcraft MTF synthetic at all? Also, Pennzoil Synchromesh is rated at GL-3, so I technically stopped running it years back when I first found out. Valvoline Synchromesh was already it’s direct competitor, and I believe Quaker State even had a generic Synchromesh formula back then. I wonder if I can still buy backstock bottles… lol
Do you happen to have any links and/or resources on this? I swear I also did run friction modified Synchromesh from AC Delco for a while in a bunch of Honda’s and Acura’s, but I personally didn’t feel it was any better compared to a regular, generic conventional Synchromesh formula. That, and most fully synthetic GL-4 75w-80 MTF’s/gear oils were better, and for the same price range or for a little more (ex: Redline, Amsoil).
It's an all synthetic fluid and probably $35 or more a quart now. I don't forsee ever changing it in that car, either. It's got a lot of miles on it and it's unlikely to be in the road forever. It's probably only been changed maybe 3 or 4 times in it's 270k plus mile life. The fluid never looked all that dirty when it was changed. Honestly, the only reason it was changed this time was because the transmission was coming out for a clutch job.
The fluid that came out was 80w-90 conventional GL4 VP Racing brand oil. It shifted just as well.
I know the Honda guys use GM Synchromesh in a pinch. And that or Red Line MTL/MTL-LV would be my pick unless an esoteric fluid is called for.
I used Chevron Dex/Merc fluid in a Ford F-150 with the Mazda M5 with no issues when the neighbor said it was popping out to gear. There was a leak that needed to be fixed.
