Using Heavy 30wt/40wt in Car speced for 5-20/30?
I've run M1 0w-40 in cars speced for 5w30
run 10w-40 in cars speced for 10w-30
even ran 20w-50 in trucks speced for 10w-30
never noticed a problem in over 100k.
I`ve always run 20W50 in my cars and can`t tell any difference at all performance/gas mileage wise compared to 10W30.
Yes, it is a probelm on systems that use metered oil pressure for valve actuation. In part, this is why v-tech does not kick-in until a set temp. Too thick and oil won't service areas of the engine that require oiling. In a engine taking 20 weight, if you want to use a light 5w30 in hot weather, be shure it's good quality and can flow like it is supposed to. Heavier 30/40? Maybe if you have nitrous or aftermarket turbo/SC then an oil like GC or M1 0w-40, but that's as far as I'd go.
I don't want to start a debate here-I'm just sincerely curious. If there is such a mechanical need for a light oil in VTEC cars, why does Honda spec thicker grades for other countries?
I've heard this before but I run Amsoil straight 30wt in my TL. I usually drive very easy during the warmup period but the other day I had to floor it pulling out onto the highway after about two minutes of run time and vtec worked like normal.
