Oil for NY Winter
Thinking of getting a project car to teach myself and my son how to do simple maintenance items.
Chances are it will be a Honda with a K engine (likely a K24z3) or a Toyota with a 2GR. Will be high mileage.
I've read 5w30 is a good way to go, but also 0W-20 is great for NY winters. I'm not upstate where it gets bitter cold, but it can get pretty cold in in the boroughs.
would it make sense to run 5w30 for 3/4 of the year and the 0W-20 for the cold months? Totally new to this, any recommendations and feedback are greatly appreciated.
thanks.
The winter rating (the number before the W) is what is important. Use any grade you want that has an appropriate winter rating, above -30 or so an oil with a 5W rating is appropriate, below that use one with a 0W rating. Or just use a 0W rated oil year-round. That's pretty much what I do.
Here are a few previous threads which may be of assistance:
30 grade oil can handle all the way down to -30 F. I've been using it year round in NJ.
Coldest Temperature Ever Recorded in New Jersey
The coldest temperature ever documented in New Jersey was a bone-chilling −34°F (−36.7°C). This record was set on January 5, 1904, in River Vale, located in Bergen County2.
Here’s what made that day so exceptionally frigid:
  • ❄️ A deep fresh snow cover blanketed the area
  • 🌫️ The climate station was situated in a valley near the Hackensack River
  • 🧊 Proximity to a pond used for ice harvesting contributed to localized cooling
  • 🌬️ Sparse tree cover allowed cold air to settle more intensely
This temperature was recorded without factoring in wind chill—so the actual “feels like” temperature may have been even lower. It's still considered the official coldest air temperature in the Garden State's history.
In your lifetime have you ever seen -30F, in my area I have seen 0, back in the late 1970's around Christmas time in New York City I think it might have been -5F when I was up in that area.
By the fact that you said NY I am going to assume you mean NYC. NY is a BIG state and we get VERY different weather here in Buffalo NY vs what you get in diet NJ I mean NYC.
Also for every one saying 5W will work, yeah it will and I can do anything once. If its -17 degrees out and your battery is not brand spanking new but marginal starting with 0W weight oil maybe the difference to get it to crank over.
But wait this is BITOG we all have 400 dollars to drop on our car battery every other year.
You've used a 10w30 at -30?
I had Mobil 1 10W30 in a 3rd gen 4Runner with the 5VZ-FE engine that spent a week in -30 to -40° F (yes, I know Celsius and Fahrenheit reach parity in that range) temperatures. Actual temperature, not windchill which is often stated to sound more sensational. It had an Optima battery (one of the good ones before Johnson Controls bought them). It cranked a little slow, but started right up every day. I sold it over 20 years later, still running like new.
When I was in college, 2nd semester freshman year it was about that in Potsdam, NY. For 2 weeks the daytime high was -10F on outdoor thermometer, not windchill, real feel BS. My little Honda Civic had 10w30 conventional instead of 10w-40. Dad said better for winter :unsure:. We didn't know better. It started but cranked at like 1 revolution /second. The battery was a "bit" larger than stock.... sized for moms 318 Chrysler!
Memories :oops: :cry:😁
0W20 is good in the arctic circle area. 5w30 is fine anywhere in continental US. i use 5W30 year round in Canada. but i have started to use 10W30 in Summer and i will start to use 0W30 in winter. my owner manual allows it.
Potsdam N.Y. to where I live in Maryland is 399 Miles away, you are right, in that we did not know better, 10w30 or 10W-40 to a certain extent is similar down to a certain temp with dino, synthetic may be different. I know a few members will disagree, and I know this is not realistic to a certain extent, for 2 weeks of the year when temps are below 0 that is the time when a 0 Weight oil would be nice. I have also heard when it gets really cold, now this is back in the day, people would take out their battery and keep it inside overnight.
The only place in Maryland that gets really cold like Potsdam N.Y. is either Frostburg, Maryland or Oakland, Maryland.
Here is where I saw the difference between 5w30 and 10w30 when it was cold, now this is on a push mower, we have a Gulley that I use the push mower on, and it would keep growing into December, the mower did not want to start at 30F, it was like trying to pull Orca or Jaws, so I had to leave the mower inside the laundry room OverNite. It started great the next day, so 1 year I changed the oil since I had some 5w30 oil leftover, Mobil 1 5w30 is awesome, and I did an experiment, and I put the mower in the garage and then started it up, pull start in 30-degree weather and all was ok.
I am merely stating 30 grade oil can handle temperature down to -30 F. So use with confidence.
But no.. I have not seen anything below 0 F.
What 30 grade?
0W or 5W or 10W
any 0W will no matter if it’s a 20 or 30 or 40 or 50 grade the W or winter rating dictates that.
Sure, but the fact that it’s a -30 grade isn’t important, it’s the winter rating. A -40 grade is good down to -30 as well, but one with a 0W rating. That’s what I used in my BMW when my daughter went to school in northern Wisconsin and she did start at that temperate a few times over the years. Actually at -30 you could have a -50 grade as long as it was a 5W-50. Operating viscosity isn’t important for cold weather like the winter rating.
