Oil for NY Winter
I am merely stating 30 grade oil can handle temperature down to -30 F. So use with confidence.
But no.. I have not seen anything below 0 F.
I want to thank you for responding back, we do have a member that has posted about starting a car in temps well below 0, it might have been -18F, I do believe the oil was Mobil 1 5W-30
I could be wrong, and I will not test this, but at -30F, some might be ok with a 5W-30, and let's stick with the last number being 30, maybe I am more Barney as opposed to Andy, but at -30 I would want the 1st number to be 0 LOL
Thinking of getting a project car to teach myself and my son how to do simple maintenance items.
Chances are it will be a Honda with a K engine (likely a K24z3) or a Toyota with a 2GR. Will be high mileage.
I've read 5W-30 is a good way to go, but also 0W-20 is great for NY winters. I'm not upstate where it gets bitter cold, but it can get pretty cold in in the boroughs.
would it make sense to run 5W-30 for 3/4 of the year and the 0W-20 for the cold months? Totally new to this, any recommendations and feedback are greatly appreciated.
thanks.
5W30 will be fine
We had a mild winter but I still use 0W-30 all year.
thanks.
I would pick one oil and be done.
A 5W-30 would be fine. When I lived in Northern Vermont, I ran Mobil 1 5W30 in the truck I used to leave outside. We saw absolute temperatures between -25 and -30 on occasion.
That said, if it makes you feel better, find a good 0W30 and use that. It’ll be fine in the summertime too.
Montana has entered the chat. HA HA
We normally get a few days here in the -30's each winter. I run M1 EPHM 5w-30 all year. Unheated garage at home, but out in the elements at work. Last year we had a 4-5 day stretch in the -30's to -40's, reaching a low of -44 one morning. 2019 F150 started every time. Battery in the truck is the original Motorcraft with 800 CCA.
Antifreeze is a concern at -40Fmost are only good to -34F
I definitely would not want to be running a 10w anything in -30 degree weather. I actually would not even want a 5w in there. If there is any chance of the temperature getting that low, a 0w oil is the way to go, especially keeping in mind that after a few thousand miles that 0w oil will actually be a 5w oil
