- Joined
- Jan 4, 2021
- Messages
- 132
The oil is fine and is not a "low quality" oil, especially when your OCI is 3-4K; mine is 6-7K or so / every 6 months2025 Subaru Touring XT with of course the 2.4 turbocharged engine...I will be changing the oil next week and with the Costco sale coming up Wednesday April 9, 2025 for 2 - 5 quart jugs for $30ish I am curious if this oil is worth the buy or should I be using something else???
this is my first oil change since buying the Outback new last October and I am at about 4K miles...I plan to change the oil every 3-4K miles only because this car does more short trips and is not my only driver...I also plan on using OEM Tokyo Roki oil filters but may also go to Microgard Select/STP Extended filters...
any thoughts or experience you care to share is appreciated...I'm not really new to turbocharged engines but I am new to flat/boxer engines and want to protect mine as best I can...no towing and mostly just day to day driving...
thanks
Bill
FWIW, if you take advantage of the current Pennzoil rebate, Pennzoil is cheaper. While I do not have a turbo, our older 2016 OB 2.5i burned more with M1 and Kirkland (but our 2014 Acura MDX didn't burn Kirkland) causing the "low oil" warning after a few thousand miles. No warning when switched to other brands such as Castrol or increased the viscosity to 5W30 (from 0W20).
As for the filter, I have been using Wix mostly due to the bypass rating.
