Well, here are a few of Redlines straight-grade racing oils:
SAE 20 (5W20) - for drag racing, circle track qualifying and race engines designed for low-viscosity oils.
SAE 30 (10W30) - suitable in well balanced racing engines for sustained high-speed use where low internal friction is desired.
SAE 40 (15W40) - for use where temperatures may be high and when a wide range in RPMs and speeds will be encountered.
SAE 50 (15W50) - for use where extremely high temperatures may be encountered and when engine durability is the primary concern.
The base oil, as we know, has the inherent ability to flow at a wide range of temperatures without the need of VII's....(duh, we already knew that!)
