Why do people say weight when it’s viscosity?
So my question is this I know the W on the label is for winter like 5W30. I understand the 5 is a viscosity that behaves well in cold weather and when the oil gets hot the viscosity is at a 30 grade. So where does the term weight come from when it all has to do with viscosity?
You have to add a few things to your assessment.
Such as the 5W would be the viscosity of an sae 5 AT THAT TEMPERATURE. Same with the 30 part, but at a much higher temp.
It’s not an assessment it’s a basic question why do people use weight when it’s viscosity?
That's incorrect.
The number preceding the W is the Winter Grade. It's a grade, just like the number that comes after the W.
The grade in front of the W is derived through CCS and MRV testing and has absolutely no relation to the number after the W, which is based on the KV100 viscosity.
Furthermore, this are no SAE 5 or 0 grades, which should be a big clue as to the flaw in that thought process.
For practical purposes "weight" and "grade" are used interchangeably.
The only thing I can think of why weight is referenced is from the oil industry when they are drilling and calling out the weight of the drilling of the mud and it’s correlating viscosity and that terminology has carried over. So if I was to call out the weight of a mud it could be 10 pounds at a 37 viscosity and that’s where the term weight comes from.
Weight really makes no sense unless you are for some reason referencing density in an equation, but a "grade" refers to a viscosity and a designation such as 5W20 refers to a viscosity "range" between cold and hot temperatures.
Viscosity is measured in either Absolute viscosity units or Kinematic viscosity units.
I think it would be far fetched that it comes from “mud weight” but you never know. It seems in many industries “weight” is used where viscosity would be a better term.
I always thought:
  • Viscosity describes Grade
  • Grade describes Viscosity
  • Weight = how much mortadella I want to buy at the deli counter.
Why do some older people say "hi test" when they want premium gas.
Why do some people say "DEF fluid" when stands for diesel exhaust fluid. They are saying diesel exhaust fluid fluid.
The general public isn't as intelligent as BITOG members are.
I demur, might be a bit of hubris. Some of the places where I do my intellectual grazing sometimes leave me feeling like a dotard. Just look above the internet swamp miasma and our equals can be found.
If you know what somebody is talking about , why correct them for minor things that don't change the facts ? Nobody is impressed with irrelevant knowledge .
As I get older I find myself working on that often.(Ie not correcting.. even if its someone telling me to inflate my tires to the sidewall psi... 😬
