Originally Posted by PimTac
Originally Posted by BigShug681
Here's an older one from a few years ago
Is this the oil you used?
https://www.amsoil.com/shop/by-prod...nthetic-diesel-oil-15w-40/?code=DMEQT-EA
It's listed kinematic visc at 100C is 15.6cSt (higher end of the 40 weight category), so it is down to 12.34 (high end of the 30 weight category) after 5200 miles.
That is surprising - it was sounding like oils with a large viscosity spread (5w40, 0w40) would consist of a lower grade viscosity oil then have added viscosity improvers to get it up to the 40 weight at temp. It would stand to reason that if the viscosity improvers get sheared, destroyed, however you want to call it with the high pressures (500-3000psi) then the oil would end up being thin. However, the oil you used was a 15w40, which I would expect to have a thicker base stock viscosity grade compared to a 5W40 or 0W40.
Not sure what to make of that info.
Do you have a UOA from a 10W30 that has similar miles on it? It would be interesting to see how the 100C viscosity held up.
I am currently running Amsoil's 10w30/SAE 30 I'm about 2000k miles away from my first UOA
Testing out amsoil on their long change intervals?
Yes, I've so far been able to extend my interval from 5k miles to 15k but I plan on making a few changes to possibly push it further once I install a bypass filter setup
