- Messages
- 268
- Location
- Grand Rapids, Michigan
The engine did not see any cold starts.
That's why I think this is only valid if you live in a very warm climate.
quote:A lot of us use Mobil 1 SS 15w50 "red cap". It has been putting out very good UOA results with my modified '99 Honda Magna. It holds its viscosity well, has a solid additive package (high ZDDP levels & high TBN), is compatible with wet clutches, and is cheaper than most MC-specific oils.
Originally posted by Jim: I bought a new air cooled motorcycle (Moto Guzzi) and I am looking for the perfect oil for it.
quote:Johnny O, keep in mind that a 10W30 and a straight 30 weight oil are the same viscosity at operting temps
Originally posted by JohnnyO:Yeah, but I bet that was on a dyno in a very controlled environment. Some car from the 60's would be okay on straight 30 weight but modern cars have a lot tighter clearances and run hotter, so I think you need a good multi-grade now.
quote:Also keep in mind that the 30 weight is better at high temps than a multi-grade. Multi-grades are used for startups. Once the oil is at operating temperature, the multi-grade component is no longer useful. [ October 29, 2003, 08:59 PM: Message edited by: rpn453 ]
Some car from the 60's would be okay on straight 30 weight but modern cars have a lot tighter clearances and run hotter[/qb]
quote:I wonder if they simulated cold starts? Or did they keep the engine running the entire time? If it's true that most engine wear occurs on cold starts, then the 10w30 should provide less wear than a straight 30.
Originally posted by Jim: The graph of cylinder-wall wear rate versus cylinder wall temperature tends to be bathtub-shaped, with wear increasing sharply at each temperature extreme (as you'd expect). But while two of the oils turned in very similar wear performance, one oil stood out as protecting the engine against wear at the extremes of temperature. That oil was plain SAE 30 (Straight-grade 30-weight). At either extreme of temperature, the maximum wear rate with 10W-30 was more than double that of the straight SAE30 oil. (The worst performance was turned in by straight 10-weight.)
quote:I've lost count of how many people have said this, but I think your dead wrong. True they are able to hold tighter tolorences these days, but that doesn't mean they are using tighter oil clearances. I dug thru some Chiltons manuals to compare the recomended rod and main oil clearances for a 1969 Chev 350 (truck) and a 1994 Chev 350 TBI (truck), the figures below. If anybody can prove or disprove any of this, please do. 1969 350 .0008-.0024 main .0007-.0028 rod 1994 350 TBI #1 .0008-.002 main #2/3 .0011-.0023 main #4 .0017-.0032 main .0013-.0035 rod
quote:It looks like for the rod bearings the clearance used to be tighter back in 69 and also the same or tighter for the mains. Urban legend about tight clearances? Maybe tighter for an engine designed in the last few years and not based off of an older engine? [ October 30, 2003, 01:48 PM: Message edited by: V6 Diesel ]
Originally posted by Kompressor: I dug thru some Chiltons manuals to compare the recomended rod and main oil clearances for a 1969 Chev 350 (truck) and a 1994 Chev 350 TBI (truck), the figures below. If anybody can prove or disprove any of this, please do. 1969 350 .0008-.0024 main .0007-.0028 rod 1994 350 TBI #1 .0008-.002 main #2/3 .0011-.0023 main #4 .0017-.0032 main .0013-.0035 rod
quote:I think you could label any 10W30, 5W30, or 0W30 as SAE 30 (someone correct me if I'm wrong please). You'd lose a lot of the market on that version of the label, since less people buy straight weight oils. As well, it probably wouldn't be able to meet many of the specifications commonly associated with an SAE 30, so you'd lose much of that market too. With a good synthetic you can meet many of those specs and still sell it as an XW30, which increases your potential market. Check out Amsoil Series 3000 5W30 H.D. Diesel Oil, for example. Seems to meet all of the specs that any SAE 30 would meet, and you can sell it to us Canadians in the winter!
Originally posted by Patman: If there is a synthetic oil which is labelled as a 10w30, but does not use any viscosity index improvers whatsoever in it, would it qualify as being technically a straight 30wt?
quote:I sort of thought that was the way synthetics were made. A straight weight oil that worked good in the cold with out all the VI.
Originally posted by Patman: I've got a question I've been wondering about for a while on this subject. If there is a synthetic oil which is labelled as a 10w30, but does not use any viscosity index improvers whatsoever in it, would it qualify as being technically a straight 30wt? In other words, could you not build a straight 30wt oil in such a way that it would qualify for 10w status too? And at the same time, if it really were made with some incredibly good base oil, could you ever get a straight 30wt which would technically qualify as a 5w30?
