Since with higher viscosity oil comes with higher oil pressure relative to the thin oils, the ECU will be fooled, and limit oil flow thus volume, so that you are overly reliant on the thicker oil film, due to limiting flow, will not control the heat dissipation of the engine also, so now, your extreme use test becomes even more extreme.
I'll take the full flow of thinner oil lubricating and cooling the engine instead.
On a side note, but still applies... over in the European/Imports Oil forum, whenever their is a BMW oil question, all of the BITOG experts say use the appropriate BMW spec oil, since BMW knows best and their oil specification/certification will protect the engine, without question. But..... when there is a particular B58TU2, specifies LL-22FE++, which happens to be 0w-12, all the sudden the people that didn't question BMW engineers and their spec, now say BMW LL-22FE++ 0w-12 specification is inadequate and go with a thicker spec oil. They trusted BMW's engineers until they broke with BITOG experts' "engineering experience designing and testing BMW engines"
