It’s the injectors you hear. My 4.0L does it.What do you recommend for normal or extended OCI? If it's a "quiet" oil that might be a bonus due to this engines known tappy valvetrain.
I was asking mechanical advice in the appropriate forum, and here oil advice, also in the appropriate forum.Basically asking the same question in multiple threads eh? Best thing you can do is replace the VVT screen filters, PCV, change your oil every 6,000km and use 5W30 full synthetic. If it is ticking so bad that it is causing you issue, then pull the heads and have them rebuilt.
It's a 13' with port injection. I don't believe they went to direct injection until 16' or 17'.what year motor? is it direct injected? if yes its noisy when going through cleaning when it also has the multi port combo /direct injection. I can get Toyota 0-20 for 3.87 to 4.00 dollar a qt. That's all I use in my Fj 4.0 eng and my 2018 Highlander. Mac
ok you are just hearing injectors. Toyota puts all that moly ln their oil for a reason. MacIt's a 13' with port injection. I don't believe they went to direct injection until 16' or 17'.
I currently have RT gas truck 5w-30 in it with a Toyota filter. Plenty of Moly in RTGT iirc.ok you are just hearing injectors. Toyota puts all that moly ln their oil for a reason. Mac
I run M1 5W30 EP with 10k OCI. Excellent UOA.What do you recommend for normal or extended OCI? If it's a "quiet" oil that might be a bonus due to this engines known tappy valvetrain.
Well if it solely for the purpose of a normal or extended interval and not related whatsoever to ticking in the 2GR-FE to quieten them down, then based on my experience owning serveral 2GR-FE powered AWD Venza's then I would stay with a normal interval and synthetic. I run 5W30 in the chilly months here in The Great White North and 10W30 in the horrid summers. QSUD is my go to, but will switch to PUP when my QSUD stash has been depleted. Fram Ultra is my go to oil filter, but Tough Guards on my shelves when they have been depleted as well.I was asking mechanical advice in the appropriate forum, and here oil advice, also in the appropriate forum.Thank you again
Apologies, location is the midwest with temps up to 80s and high 90s at times in the summer and winters that have been known to reach -10 or -15 briefly at it's peak but generally in the teens.asking for a grade opinion without a location is wasting everyone's time.
Yes. the "Taco Tick"It’s the injectors you hear. My 4.0L does it.
