- Joined
- Mar 10, 2023
- Messages
- 184
Previous owner of my 13 civic did that. Changes at the wick lube place on intervals recommended by oil minder. Had sludge and varnish. VRP took care of both over 20lk miles and 4 changes.I basically did that for 18 years with a 30 grade in my Odyssey and got an engine with the entire top end heavily varnished (which is slowly being removed by Valvoline R&P).
Do not run just any oil and do not follow the minder if you want to keep the engine clean.
