Originally Posted By: TaterandNoodles
Originally Posted By: 3Toyotas
Just curious, how big is your home and what are your extreme hi and low outdoor temps? Is it slab on grade or all above ground?
2x4 eterior or 2x6?
Just interested in the difference between NC and Utah sizing.
The house is 2500 sqft with a crawl space no slab although allot of the homes in this area are slab. All of the exterior walls are 2x4 and it was the coldest its been in the last 4 years about 1 week ago. It was in the teens
-8C or -9C for the rest of the world. Highs in the 90's are not uncommon in July and August, anything close to 100F is very rare. But loads of hummidty will make even a low 90's day feel just miserable to work in. I've lost 7lbs in about 3-4 hours just cutting the grass etc.
Pretty close to here in Utah, but we do see 100+ degrees about 2-3 weeks in July. We don't experience the humidity you do though.
4 ton of a/c is bare minimum for this area in a house with 2400 sq ft. When we run into homes this large, we usually opt for the larger 5 ton. Too bad they don't make a 4.5 ton, which would be ideal for you.
If your old one is the same size, how did it do on the hot summer days and where do you set your thermostat?
Most people here like it at 72 degrees, and some at 70. A rule of thumb to go off of is, if your t-stat gets it 25 degrees F lower than outdoors it's doing a good job. Other words 75 inside and 100 out is doing good, anything better means you have a good duct system.
I can get my house at 69 degrees when it's 103 outside. I have a 4 ton as well, but my ductwork is sized properly with plenty of supply & return. A .07 static pressure to be exact.
I'd imagine with that much humidity, you'd be sweatin all them pounds off pretty quick.
2x4 eterior or 2x6?
