Whilst my current insomnia is going to see my through until dawn, I thought I'd share this:
Working for myself as a French car specialist mechanic, a seemingly mint Peugeot 309 diesel came in with persistent brake fade that several other garages couldn't fix.
They couldn't find a cure because they were seemingly bone idle.
And the consequences potentially very, very scary.
Please bear with me.
An unusually firm brake pedal, yet the pump-driven engine servo was fine.
Braking from anything above say 20mph and there was a remarkable lack of retardation.
To say the least.
A simple fix. The brake discs - unvented type - had worn to just under 3mm thick. The thinnest clapped out discs I've ever come across.
The failure of the other workshops to spot this was laziness. Viewed through the front wheel slots and you could see lovely shiny discs.
But the a proper inspection revealed 2xdiscs worn to hardly any thicker than a 45rpm single.
The thin discs couldn't get rid of the heat. The pad material was operating on literally red-hot discs and rapidly the temperature of the parts soared.
My local motor factor was selling complete rear brake assemblies for this car, all mounted on new back plates for a bargain $16 both sides.
Pads/discs for under $19. Bendix too!
New pads, discs and fluid change: everything like new and photographic evidence for the customer.
He was happy. I was even happier.
47 years on and I still love my job.
To say the least.
