Thoughts on only changing oil filter every other oil change
I have not heard any good argument why filter needs to be changed every time, seems more of a personal preference.
Just thinking out loud. As a retired engineer, if an auto manufacturer has a recommended OC every 10-11 k miles, what's the wrong with changing the oil every 4-5k miles but continue using the filter until the next change? That's well within a "single" OC interval, and assuming you remove the old oil in the filter at the OC.
That would be good for the environment and good for your wallet.
But the old oil that remains in the filter would be going the full 10k OCI.
Also, so many oil filters have been cheapened by their manufacturer so running an oil filter to 10k miles increases the chance of something catastrophic happening (tears of the media, excess glue dislodging, etc), that it would be safer to change the filter at 5k miles.
I'm fortunate enough to have a front row seat to some of the amazing progress in filter media advancement by nature of the job I do. Now I work primarily with diesel fuel filters, but the media and such a essentially the same for oil, just slightly coarser.
ON media advancements alone, the same fuel filters that used to limp to 500 hours of service are now making it to 1250-1500 hours and beyond-- in the exact same cans. And they do this with no decrease in filter efficiency.
On the lube side, our T4 spin on filters use a nominally 20 micron media vs the 30 micron of the T2 and earlier lube filter. This, despite calls for ever-longer filter service intervals. The advancements in media make it possible.
Modern nanofiber media does not lose efficiency over time like prior generations of media can, so they filter as well as new even when nearing the end of life.
In other words, the filter isn't used up until its in bypass for anything but the coldest start.
If I were to try to leave an oil filter in/on for 2 OCIs, it would eat at my psychologically and I would cave and change it during the 2nd OCI. I just couldn't do it, regardless of what the data are.
Throw all caution to the wind and change filter every 5k and oil every 10k just to be different. 😁 :ROFLMAO:
I prefer to not add the old oil I'm getting rid of to the new stuff I just added even though there is probably that much left with the Fumoto or Valvomax anyway. Why add more.
As stated, I'm under there, probably had to remove skid plates so might as well do the filter also.
I think that some vehicles the filter is tough to get to.......or at least it is not terribly easy. My LX570 has I think 8 bolts to remove a large steel skid plate, then the filter. I have thought about running a 10k on the filter, and 5k oil changes.
Deere?
Yes, Fleetguard and Donaldson are playing in a very different sandbox from First Brands and Mann-Hummel
Fairly certain the Heavy Duty and Industrial sector which often these areas are run by very technical people which can probably see though the typical marketing BS that both Donaldson & Fleetguard sales and contracts would have to be handled by a sales engineer.
Cutting corners in this part of the market can mean a permanent loss of business from that particular customer if they don't get what they want. How do I know? I see it all the time. Even our company loses business if we can't meet a customer's specifications or demands. A minor sudden change of product dimensions and performance without approval from the customer will instantly spark complaints and recalls. Unfortunately the typical MBA doesn't see this consequence until they're at risk at loosing their job.
This also aligns why I see Toyota TRD dropping Champion Laboratories which formerly supplies their synthetic filters to dealerships.
I do this on my Caravan with Pentastar....2x yearly oil changes around 3K, each, changing the filter every other oil change. I want to minimize the times I tighten and loosen the plastic filter housing cap, knowing these **** things can break and leak.
And....the oil drains out of the housing. Unlike a spin on filter, the amount of old oil is less than what's left pooling around in the engine. I don't see a downside to this with the Pentastar and some other cartridge applications.
Please keep talking.
Heck I ran an ancient tough guard filter to 20k plus over multiple OCI’s without issues.
Nothing...it's fine. Question is you are spending time under the car $10 or less and a few more minutes for a fresh filter is why most say "why?".
Some of my stuff has multiple oil filters, at $30-60 each.
I still do 250hr OCIs.
On something running full out, maybe I'd bump it to 500.
Many shops here do 21 days or 500hrs, whichever comes first.
