- Messages
- 182
- Location
- The Netherlands
Today i read something interesting in a dutch automotive magazine that is handed out to a lot of repair shops, they also discuss a lot of common engine problems and discuss and clarify things with the help of experts.
This topic was about sticking to oem oil spec or going to a different spec/weihgt. So one of our favorite subjects
One lubricant expert stated that you should stick to oem wheight/spec (which i agree with) because with switching to a thicker weight the oil pressure will increase which in terms will also put more force/pressure on the timing chain tensioner because those are motor oil hydraulicly actuated.
I thought this was an interesting point which probably has some truth to it: thicker oil= less internal leakage/flow = higher pressure = more force on tensioner = more tensioning/stretching force on the chainlinks and sprockets itself.
Especially when the oil is cold, and by using thicker cold grades then oem spec.
Some engines are known for having poor timingchain quality, other have no problems at all.
I guess that maybe the engines that are known for poor quality might wear a little faster, but i dont think it will cause a lot of trouble on the cars that dont have any problems with it generaly.
