OEM vs aftermarket ATF
I shared a shop with the Cadillac techs at my old dealership so I know exactly what you are talking about. The guy next to me was the designated transmission rebuilder. That was all he did. I did not envy his job.
The transmission flush machine taps into the line from transmission to cooler/radiator. It nearly universal on all vehicles and i do recommend having it done around 50k. I will be doing a drain/fill on my transmission at 40k because I am OCD.
BTW:
I have posted about BiL’s 400K Silverado.
Mobil Super bulk - bulk filter - 5K miles.
But yes, was doing the BG flush at 50K
That is the machine I used for years.
Is that one that uses the transmission's own pressure/pump? Or it has an external pump? I hear the external pumps are too powerful and will churn up all the gunk in the bottom of the pan. Then mess up the transmission. Hence why flushes have a bad reputation.
The machine has an internal pump but it is ONLY used to evacuate the machine once full. The vehicle is started and idles during the flush process utilizing the transmission pump.
Just an update in case anyone was interested.
I ended up buying a quart of Valvoline Dexron VI fluid (Blue bottle), and added 6oz or so into my transmission. That little shudder I felt during the first shift from R to D and from 1 to 2 is virtually not there anymore. But, it is also a little warmer outside. So not sure if it was the temp, or the fluid level.
Best I can tell, the fluid is now borderline overfilled per the dipstick. But also kinda hard to tell with this dipstick. Another 1000 miles and I'll be doing an oil change and another drain and fill of the transmission. Will also do a tire rotation, so might try pulling the side port to see if a lot of fluid comes out that way or not - if that's more accurate than the dipstick.
I mentioned this video earlier in the thread, but couldn't find it till now.
2018 Chevrolet Silverado 2500 HD 6.0L dropped transmission pan, changed filter and topped off with A/T fluid after buttoning up at 65K miles. Didn't touch it again until this year at 123K miles and had the dealer do the complete transmission fluid exchange. The technician said it was "relatively" dark but it was not burnt smelling so all is good.
Pickup tows a 7,000# travel trailer less than 2 1/2 mo. out of the year which includes a trip up and down the AK/Canadian Highway to lower 48 at close to the 9,500# GVWR for the pickup. The rest of the time is a daily driver and not even pushed to its limits. Good for another 60K or so. If it was more months out of the year towing or with a heavier trailer, I definitely would increase frequence of fluid exchanges to every 35K-45K miles. Pay a little now or pay a lot later.
If a transmission specified dexron, Macon, or ATF-4, is buy it off the shelf. Otherwise, OE.
There is nothing weird about Lubegard and it is very well tested for 40 years. It works and will cause no harm. It's been in all of my transmission, GM, Ford, BMW, and Mercedes for 30 years. I use either Valvoline Dex VI or Amsoil. Even in BMWs with the GM transmission. Maxlife has a big following because it works. Any licensed Dex VI will be fine.
And who do you think makes the OEM fluids? It is the companies that make and sell the aftermarket fluids. The OEMs don't make their own, they contract it out.
Yep, this gentleman predated Dr Les at Mobil
https://www.transmissionmissiondigest.com/lubegaurd-scientist-dr-landis-passes-away/
FWIW, I've used that exact fluid, Pennzoil Platinum® LV Multi-Vehicle Automatic Transmission Fluid, in both a 2016 GMC Terrain that calls for Dexron VI and a 2018 Ford Edge 3.5L V6 that calls for Mercon LV, and it works perfectly in both applications. It should, since it is officially approved by both GM and Ford. It's also consistently the cheapest Dexron VI and Mercon LV-approved fluid I can find. Menards sells it for about $6 a quart.
I ran the Amsoil normal ATF at the time mid to late 90s. It was in a Lincoln Versailles that took Type F. My brother's vehicle. He did not have a problem with using the Amsoil in the type F transmissionmission. Though Amsoil was not recommended for it. My brother's choice......
I used the original Amsoil ATF in Dexron, Mercon, and Mercon V transmissionmissions. I also used it in the Mercon V rated transmission for the Fords when Amsoil gave it the approval. I ran it in a Ford Taurus for 250,000 miles and the transmission shifted perfect. I also used it for the troublesome Dodge fwd transmissionmissions from the 90s-2000s A604?
The fluid is bullet proof, and never let me down. That being said I always wondered how it can have so many certifications? But using it exclusively for 30 years, the transmissionmissions have always shifted very nicely for me.
