Run 0w30/5w30 at 5k mile oci and don't worry about it. With Honda fuel dilution problems in the recent motors, I would not go beyond 5k mile oci with whatever you decide to use.
depends on how cold it is, if you are running a 0w20 vs 5w20 the latter may flow faster.Would it just take longer, but get there all the same?
I’ve run 0-30 for 10+ years in my Honda which is specked for 0-20. Makes me feel better when driving in very hot weather.
Mobil 1 Advanced Fuel Economy, which is often sale priced at Walmart and Canadian Tire.What flavour 0w-30?
I only know of two API SP 0w30 oils;
1. Mobil 1 Advanced Fuel Economy
2. Petro Canada Supreme Synthetic
Doesn't the Lotus Evora use that same Toyota Supra engine? I've read that the Evora recommends 5w40.... I'd just use the 0W20 unless I was tracking the car regularly and not worry about "high revs" during daily driving. Toyota specs an 0W20 in the Supra.
I'm in a similar boat. In my old Forester XT, 5w30 was recommended and it allowed up to 10W-40. Given the issues with the EJ engine's bearings, I always went with a Euro xW-30, 0W-40, or 10W-40.Can you talk some sense into me? I recently bought a 2023 Acura Integra, basically Acura's version of the Civic Si. I've got 900 miles on it and am thinking of doing the first oil change this weekend. I just can't wrap my mind around using 0W-20 in a turbocharged engine that will see a lot of high revs.
I joined this site in 2003 and always watched the 20 weight debates from afar. This is the first time I've ever had to run a 20 weight, now I'm conflicted! I know that millions of engines have lived long and productive lives on 0W-20, and that this Honda L15CA may have been designed with 0W-20 in mind. But I also know that I will drive this harder than a typical commuter, and that the EPA requires them to state that only 0W-20 should be used, regardless of what the engineers would prefer, and that thicker oils are specified in other markets that don't have this EPA requirement.
As of right now I'm planning to find a fully synthetic SP rated 0W-30, with the highest HTHS and lowest NOACK numbers I can find. Am I crazy?
No idea - the GR Supra specs 0W20, that should tell you all that is needed here. That is a far more powerful engine that the Intergra.Doesn't the Lotus Evora use that same Toyota Supra engine? I've read that the Evora recommends 5w40.
If the Evora does use the same engine and recommends 0w40, that tells you something important: if you drive it hard you should have thicker oil. This wouldn't be the only time that a company recommends thicker oil when driving it hard.No idea - the GR Supra specs 0W20, that should tell you all that is needed here. That is a far more powerful engine that the Intergra.
As I clearly stated in my original post above, it's more than likely that the OP isn't driving the car hard. How many people really "send it" in their daily cars that would require you to run a thicker oil? I'll say nearly 0%. Just b/c you have a quick little car like the Integra doesn't mean on your daily commute and accelerating hard to get on the highway you need special oil beyond what the OE says to use.If the Evora does use the same engine and recommends 0w40, that tells you something important: if you drive it hard you should have thicker oil. This wouldn't be the only time that a company recommends thicker oil when driving it hard.
I'm really confused on what you're trying to say.At what temp gradient does 0 reach 5 compared to 5W20. Who overloads an engine while it`s warming. Not sure this 0 grade is all it`s purported to be. Will look for some studies on this subject.
Honda/Acura only list 0w-20 for this engine, regardless of country (at least the US and European owners manuals I found online).
That said, I too would have issues running 0w-20 in any turbo engine. I would be much more comfortable with a xW-30 oil for longevity.
I run 0W-20 and 5w-20 oil in several of my vehicles that are spec'ed for it, so have no real issues with "thin" oils, but none of them are turbo's either.
No, We all want to think we are smarter than every engineer at Honda.Can you talk some sense into me? I recently bought a 2023 Acura Integra, basically Acura's version of the Civic Si. I've got 900 miles on it and am thinking of doing the first oil change this weekend. I just can't wrap my mind around using 0W-20 in a turbocharged engine that will see a lot of high revs.
I'm waiting for the
As the oil warms the VII maintains viscosity, at what temp is 0 equal to 5. And is it of any importance. Wouldn`t the higher number be of most relevance esp for fuel efficiency. I differ to those who know more than I which is most everyone on this site.I'm waiting for the
I just don't think anyone knows what this means. I'm not trying to be mean, I, and probably other members will need you to try to explain what you mean by that, so we (most likely other members) can help answer your question.at what temp is 0 equal to 5
