Friend of mine called me the other day, after his '97 Suburban C2500 (Vortec 7400) broke down. Wasn't exactly very convenient at the time, considering I was washing the dog with the other half and I had 6 missed calls by the time I got to the phone.
I had a feeling this was coolant related by the way he described - "there was no acceleration and the engine shut down". Pulled off the radiator cap (which let off a lot of steam for 5 minutes or so) when I got there and it took roughly 4.5 gallons of 50/50 mixed coolant before I could bring it up to the full level. The engine would just crank at first, and only started after opening the throttle plate slightly. Didn't seem to be running right, so I got it on a flatbed and let it sit overnight before I started work on it yesterday.
The radiator was leaking from 7 different spots, and the coolant bypass adapter located right behind the alternator. Spent the whole day yesterday replacing the radiator, all coolant hoses, thermostat and coolant temperature sensor, which shot out the engine. The coolant temperature gauge wouldn't register a reading, so when I decided to check it, there was no sensor there - the threads were stuck inside, but the sensor itself was nowhere to be found. Boy was it a job taking the stuck threads off.
When I was done I decided to change the oil, and let it drain whilst I fill up the cooling system. As I was I was pouring coolant into the radiator, it was draining out the oil pan at the same rate! It's like the drain petcock was off the radiator and I was trying to fill up it. The engine's in for a cylinder head job at the moment, which will run him $850 if the heads aren't cracked. I think rebuilding the bottom end wouldn't be a bad idea at this point. It's a shame though, considering the engine has less than 130,000 km (81,250 miles) on the clock.
