Synthetic Oil Leftovers - What OCI ?
PNW
After 1.5 years of various fills using Mobil 1 0W20 , 5W30 , Quaker State Ultimate Durability 5W30 and Pennzoil Platinum 5w20 I have enough synthetic leftovers to do a complete fill for the wife's grocery getter '07 Kia Sedona 3.8L V6 ... Any reason why I can't go with a 6,000 mile / 6 month OCI on this Frankenstein synthetic oil mixture ?
No reason why a random mix like that couldn't go 6k miles. Use it at the next oil change without hesitation.
I wouldn't. Then again, I wouldn't mix oils like this unless I didn't really care about the car. It's not like the engine is going to fail overnight, but mixing so many different oils is basically maximizing the odds of additive clash.
If you do decide to run this brew, I'd recommend half that interval.
Mixing all that is fine, since all their additives come from Infineum, jointly owned by Shell (SOPUS-Pennz-Quaker) and Exxon-Mobil.
My understanding is that all api motor oils are compatible. I don't see an issue. Possibly a sodium based add pack mixed with calcium base could be problematic bit I seriously doubt it and you didnt name any sodium based oils anyway.also isn't sodium actually a type of calcium I believe I read?
What?
http://www.ptable.com/#Writeup/Wikipedia
Unilever makes food and cleaning products. Are those okay to mix because they come from the same company?
"Compatible" in the sense that they won't have any immediate horrible chemical reactions when mixed. That doesn't mean they'll actually work well together.
It's a floor wax AND a dessert topping!
http://snltranscripts.jt.org/75/75ishimmer.phtml
We're talking about oil.
When someone can show me actual proof, not just opinion, that mixing oils is harmful, then I will stop. Nothing wrong with it.
What?
It was a question. If you know better you should say so instead of just saying "what". Maybe one day I can be a super bitoger like you haha
I mix oils almost every oil change. Sometimes up to 4 different oils. Usually run a 9,000 mile interval. Never had a problem.
What do you mean "isn't sodium actually a type of calcium"?
I only have a minor in chemistry so be gentle.
OK well I'm proud for ya if that's what your looking for
I just thought I read somewhere that it said that but wasn't sure. That's why it was in the form of a question.
Best comment here.
