- Joined
- May 19, 2022
- Messages
- 258
Used many stp 3614xl and 3600xl’s with no issues. Always seemed like good filters. And no louvers on these
100%. Unfortunately, we now own cars that use cartridge instead of spin-on.You’re like me you enjoy cut and posts my friend.
Seems lots of people think the "built quality" has gone down because some have slightly wavy pleats after use. How is that really a "quality problem" when other brand filters can also have some wavy pleats after use.After my stash of OEM Mopar filters are done I’m looking for a good 99% 20 micron filter to start using. It was going to be Fram Ultras but it seems the build quality has gone down hill as of late.
Not all that matters, but one thing of many that matters.All the matters about an oil filter is that it doesn't fail in use.
A few more PSI of dP at high flow rate isn't really going to matter to a positive displacement oil pump.It's also less restrictive than the FRAM, and the STP probably is as well given the simlilar media.
Poorly cut threads, lousy glue jobs, wavy pleats, and rusty base plates from on newish date codes. I don't think there referring to just one thing.Seems lots of people think the "built quality" has gone down because some have slightly wavy pleats after use. How is that really a "quality problem" when other brand filters can also have some wavy pleats after use.
What "build quality" are people actually talking about?
I don't recall seeing any "lousy glue jobs" on Ultras posted here. Many other filter brands with sloppy glue jobs have been posted however. All those things can happen on may oil filter brands. Wavy pleats are not quality issues - it doesn't affect anything but the visual looks.Poorly cut threads, lousy glue jobs, wavy pleats, and rusty base plates from on newish date codes. I don't think there referring to just one thing.
I’m glad you responded, you’re one of the members that I highly respect your opinion here.Seems lots of people think the "built quality" has gone down because some have slightly wavy pleats after use. How is that really a "quality problem" when other brand filters can also have some wavy pleats after use.
Technically, it's not really a "quality" issue, because it just boils down to "feelings" on how it should look in someone's mind. Going with that logic, every filter that doesn't have laser starlight pleats after use must be "cheap" and have a "quality issue". They really don't, nor is it a functionality issue. It's only a visual characteristic seen after use ... that's all.It is a quality issue… Before welfarized by First Brands… Fram EGs looked better than this new cheapened “ Ultra”….
So yeah… it is a quality issue. Enough of that wavy action does not lead to good results. Especially in the taller and longer oil filters.
I think Wilson's case was pretty unique and most likely not a typical situation, and isolated to cartridge filters. I don't recall seeing any spin-ons that used that "pressed together" seam method. Could have even just been a bad manufacturing batch. Now that would be a "quality issue" ... but wavy pleats after use is not.I wouldn’t run an OCI long enough to even make them wavy. Wasn’t it an Ultra that Wilson found holes in the media near the seam?
Examples of a quality issue:
1) Badly formed louvers.
2) Sharp burrs on the base plate holes that cut the ADBV.
3) Poorly machined and/or contaminated base plate threads.
4) Paint over spray on the base plate.
5) Leaf spring or ADBV installed backwards.
6) Excessive glue in an area that could break-off and go into the engine.
7) Bad crimp job on the can to base plate causing a leak.
8) Not enough glue between the base plate and base gasket plate causing a leak.
9) Bad media seam crimp job.
Gonna have to agree to disagree on wavy pleats being a "quality issue". If they start out straight, and then become wavy from use without tearing or causing any performance problem, then it's not really a "quality issue", It's purely a visual look issue. It's not a paint job on a $85K vehicle where the looks of the paint directly correlates to the quality of the paint job, lol.No is a quality issue…
You can play and dance around all you want to…..
But it is….A quality issue.
The pre First Brands EG was better than the welfarized Ultra…
You would and rightfully talked about how bad Purolator filters m we’re with wavy filter media in them. You know better…
And wavy pleats because of too little filter media can in fact lead to….
Tearing…. Which has been documented on here many, many, many, many times…
If pleats were very widely spaced, and the media folded over and tore, then it would be a quality issue because it was manufactured with poor quality due to the wide pleat spacing. You can bet the engineering design drawing does not call out wide pleat spacing - if so, then it's a bad design issue.
So if the factory manufacturing guys can't meet the design drawing, then that would be bad manufacturing quaity. Same goes with louvers - if the factory can't form the louvers per the design drawing, then that's obviously poor manufacturing quality.
I talked a lot about wide pleat spacing on Purolators, not weavy pleats. Two separate things. Widely spaced pleats that are straight can still tear, they don't need to be wavy to tear, they just need to bend over too far to the point where the media can't take the stress. We've seem badly bent over pleats that don't tear and many that do tear, and we've seen many filter brands with wavy pleats without any media tears. That's because tearing media also depends a lot on the flexibility and bitterness factor of the media itself, which is more of a design issue of the media. It could be considered bad quality of material if the design or manufacturing of the media didn't meet the design targets for the media, and that caused an issue like tearing too easily. But wavy pleats after use without any media tearing isn't a quality issue, its simply a visual characteristic of the media from use. That's my story, and I'm stickin' to it.![]()
A spec is a spec no matter where an item is made. But with that, I do understand your concerns.I'm not big on these. They seem to source them from wherever they can. If you look at different numbers they are clearly built by different manufactures. Some of them are Champ built, I'm not sure what this one is. I just find it hard to believe that they can make a blanket spec for the line when they are purchasing them from more than one vendor and don't have any quality control over it. This is a 5.7 hemi filter. Doesn't look very awesome to me. I also added a Parts Plus/microgaurd/etc to compare.
Nah, not making "excuses". I'm just way more objective about it and don't let feelings get in they way. The way filter media "looks" after use is purely subjective if it doesn't cause any issue besides how it looks. Everyone can use whatever "criteria of quality" they deem necessary to chose a product, but slighty wavy pleats isn't a big factor for me. I've seen some wavy pleats in other filters I've used and cut open, but it didn't make me go off and look for a different filter because I choose performance over looks as a main criteria.You make excuses for First Brands obvious drop in quality in what they have done…
The latest cut and open filters have been looking better… Maybe just maybe they are at least fixing the issue. It does appear that way.
You and I just fundamentally disagree…
The sun came up today too…
Ohh well.. That happens.
Johnny248: I prefer the Parts Plus XL filter you posted for the larger holes and no slits like the STP filter. But Parts Plus stores have become few and far between in the Southeast.
