Squeaky Brakes -Porsche Cayenne
As Trav said, Textar, ATE, Pagid/Mintex or Jurid.
European vehicles in the huge majority come with pads of these manufacturers.
It could be any of them, and one manufacturer could make a pad for one model and another for another (BMW X5 E70 is Textar, 3 series E90 is Jurid for example when you getting OE BMW pad).
The Brembo HP2000 in brembo calipers is very quiet on my car.
The Ferodo DS2500 on the rear give off a light squeal and sometimes a groan. TRW mono piston calipers with handbrake mechanism
I have a buddy with 997 that I changed brakes on (rotors, pads, sensors, fluid), they started to squall a bit under a week later, turned out to be pads' retaining springs applying too much pressure and preventing pads from moving.
About to pull the trigger on some trw pads but came across a set brembo ceramic pads that had good reviews
Should I just stick with the Trw?
Ok, Went back and found the link from Trav- Will order the textar ones today.
I did have the rotors turned , so if this is an issue I will need to replace
If you are still above the minimum thickness after turning I would say you are fine.
I always do rotors + pads though.
