I agree with Char Baby and Trav, but I'd try using the brakes a little harder first.
Performance vehicles are meant to perform. Use the brakes gently and they will be noisy. Use them like you are supposed to and they will be much quieter. See it almost every day at BMW.I agree with Char Baby and Trav, but I'd try using the brakes a little harder first.
they make pads (and calipers) for a lot of manufacturers yesBeen looking at the pads suggested
is TRW also considered oem?
And control arms, etc.they make pads (and calipers) for a lot of manufacturers yes
IMO EBC or Hawk. Get them brakes braking, to hell with the noise!Ok. So would Trw be a good pad to go with or should I go with textar
The Brembo ceramic pads are noisy IMEAbout to pull the trigger on some trw pads but came across a set brembo ceramic pads that had good reviews
Should I just stick with the Trw?
If you are still above the minimum thickness after turning I would say you are fine.Ok, Went back and found the link from Trav- Will order the textar ones today.
I did have the rotors turned , so if this is an issue I will need to replace
