Squeaky Brakes -Porsche Cayenne
Ok, Went back and found the link from Trav- Will order the textar ones today.
I did have the rotors turned , so if this is an issue I will need to replace
Hopefully you went to someone who understands how to properly machine rotors. I see a lot of rotors with more runout after machining.
Update. Replaced the pads with Trw ceramic pads about a month ago . Rotors looked good so didn’t do anything with then. Seem to be perfect now. Haven’t noticed any noise. I did find out the noisy “quiet cast” Bosch pads I replaced were semi metallic
Thanks to all for the help!
Textar is a great pad with great bite. They are the original pad for our GS350 F Sport, which has a horrible squeal problem. There is a TSB for the noise which only squeals just a little when cold, then they are fine. The Textars had horrible bark and great bite.
I think I paid $90 for the TSB pad at Lexus. Unfortunately, worth every penny.
Glad it solved your problem. I went about a year cleaning, greasing and making noise.
