✨HPL Results✨: Did 3,000mi make a Difference?
One of my cars is a 2003 Hyundai Tiburon 2.0L
I do Mobil1 Full Synthetic oil changes on it every 3000mi (due to habit mostly) I also run a couple oz. of Seafoam through the crankcase before each OCI. I am the second owner and have had it for 7 years or so. The original owner was a girl who's parents bought her the car new for college.
At 223,900mi I pulled the valve cover to replace the gasket, but despite my meticulous maintenance I was disappointed to see significant varnishing (I posted a thread about it here awhile ago). :( I changed the oil at 225,000mi.
WELL, I was recommended to use HPL's synthetic cleaner oil so I substituted ⅗ quart of Mobil1 with HPL to engine. The engine does consume oil (1qt/1000-1500mi) So I used the remaining ⅖ of the HPL to top up. Car is now at 228,000mi. Here are the results:
What is not known is what oil and what OCI's were done by the 1st owner of this vehicle. I highly doubt the 1st owner used Mobil 1 synthetic oil.
To the OP, how many miles were on this engine when you bought this car 7 years ago?
@Brian123 I bought the car with 160k. I mean, it burns oil and has blowby.
@OVERKILL I actually took a clean microfiber and wiped away a little in that corner. Didn't come off too easily.
@BMWTurboDzl yeah, I was expecting a little better but after comparing the two nothing noticeable.
@fantastic was a 3,000mi test.
@Astro14 @Rand yes ⅗ of a bottle then later the last ⅖. I used the 40 Weight. I will update the OP to include this missing information.
@andrewg and I've only ever used Mobil1 High-Mileage too. 5w30, 10w30, or 10w40 depending on time of year; I prefer the 40 weight.
*Now* for a time around 200-210k I used Shell Rotella T6 5w40 which is a diesel oil (for the viscosity & belief that Diesel oils are more heavy-duty). I stopped using it because of the cost. May try Mobil1 EuroFormula so I can get the desired "5w40" weight.
*Now* for a time around 200-210k I used Shell Rotella 5w40 which is a diesel oil (for the viscosity & belief that Diesel oils are more heavy-duty). I stopped using it because of the cost. May try Mobil1 EuroFormula so I can get the desired "5w40" weight.
So are you going to run one or two OCI's of HPL PCMO?
I think I'll stop here. Pulled the valve cover off this morning to check while I did another oci. @BMWTurboDzl Afterall, the 1qt bottle cost $22.82 (that's with the BITOG discount).
It's possible there's just too much insoluble varnish deposit to effectively remove it. It could also need a more aggressive approach. The HPL PCMO and HDMO oils clean more aggressively than the HPL EC. The EC is designed as a transition, to remove loose sludge and carbonous deposits slowly before switching to the more aggressive PCMO or HDMO. If it was me, I would replace a whole quart with the EC and run to 230,000 miles. Then switch to the PCMO.
