gathermewool
Site Donor 2023
Originally Posted by jssaab
My sludged engine got 22-23 reliably on the same drive now it is where it should be, 28 on the highway ( no better, just back to where it should be.) I changed one variable, I added MMO. (temperature the same, drive is the same, I have not lost any weight (but trying), the air in tires not touched.(if anything less since I have not checked and air only leaks does not build at the same temperature (le Chatlier's principle - since you quoted Feynman) The only way to check it would be to let the engine sludge again and see if the mileage goes back down and repeat. Not trying to prove anything, just reporting an observation or as Feynman woudl also say, "The idea is to try to give all the information to help others to judge the value of your contribution; not just the information that leads to judgment in one particular direction or another."
I think my theory about the VVT solenoids could be the reason, but whatever,
You did not just add MMO. You bought a sludged engine and...changed the oil. That was step one in de-sludging. You then changed the oil again; step two of de-sludging an engine. MMO is simply along for the ride. No one reading this or your previous threads should focus on MMO as the main contributor here, but the fact that simply changing the oil and continuing with a prudent OCI is key to slowly and efficiently cleaning a sludged engine.
Your theory about VVT actuation is very plausible.
