That probably is a whole different topic.
Yeah - while mechanically true - carrying without a round in the chamber is a whole separate topic. Lots of Agencies/departments would be against that kind of carry, even as they have level 3 holsters.
If you want to be perfectly safe - no chance of discharge - keep your finger off the trigger. That is -
off the trigger. No slight pressure, no prep, no weird bits stuck into it.
It still hasn’t been shown that the gun will go off with the various slide manipulations if there nothing pressing on the trigger. If it can be shown that the gun will go off through slide manipulations/bumping alone, no trigger tricks, then, we have a defective firearm.
I carried an H&K USP compact for years. LEM trigger. No external safety. Hammer fired. 8 lb pull. No way that thing was going off no matter what you did to it. The trigger had to be pulled for the hammer to be moved to hit the firing pin, basically a DAO. Since then, Glock won the replacement contract when the H&Ks started to age out (still irritated with that decision, like trading in my Mercedes for a Camry, but, hey, not my call).
If you don’t like the Sig, P320, don’t buy one. I was intrigued by the chassis system that allowed different grip modules. I thought that was a great feature. A great concept. One gun, that with a few $$ in plastic parts can change from compact to full size. I ended up buying a gun with that same feature - the Springfield Armory Echelon. A truly impressive pistol. I reviewed it on BITOG last year when I got it. Back on Sig…
What’s going to be interesting is seeing what the US Military does - the P320 passed a battery of rigorous testing to win the contract, there are hundreds of thousands of pistols in that contract.
For the record, I have an Sig P365, in which I have perfect confidence. I don’t appendix carry, that’s another topic, as well, but that little gun is a great gun. Striker fired. No external safety.
I also have a Sig P227, a gun that they discontinued, sadly, because it is a DA/SA hammer fired with de-cocker and looks a lot like a P226. I got a great deal on it, and bought in on impulse when I saw the listed price in my LGS.
It holds ten rounds of .45 ACP. Better than the P220 on which it was based, and better than a 1911, but with a smaller, more ergonomic grip. Excellent reliability and accuracy and improved capacity for that round. It’s a great gun. I have perfect confidence in that one as well. For a while, it was my “nightstand” gun, and still has a streamlight laser/light on the rail. Again, no external safety.
So, back to the topic at hand, the P320 - I am not yet convinced that the Sig P320 has a mechanical problem. It may, but I haven’t seen any other gun “tested” by sticking screws into the action and then wiggling the slide. That’s not a test that any agency uses. I am not convinced that is a reasonable test.
But I am convinced, as others have said, that the Sig P320 has a public perception problem.
A huge public perception problem.
It reminds me a great deal of Toyota’s public perception problem - Toyotas are death traps that accelerate out of control. Nobody can stop them. They are unsafe killer cars. Remember that? All the clickbait? All the news stories? Every one of those crashes could have been avoided, by shifting to neutral and stepping on the brake, but instead of pointing that out, every story, every. Report talked about how the machine was at fault.
The problem that Toyota faced with those incidents, was that there were millions of them on the road, so the “one in a million” chance happened to Toyota several times, but to smaller sample sizes of cars, not at all - which made it seem like a Toyota problem, not a floor mat getting stuck in the pedal and driver error problem.
That is part of what’s going on here - there are millions of P320s out there - so, the “one in a million” malfunction, statistically, is going to happen to a P320 a lot more often than, say, an H&K VP9, or an Echelon.
So, it remains to be seen - is the gun design itself defective? Or is this simply a public perception problem?
