Never , ever , use " Flushable Wipes " . Ever ...
My tank and drain field is 60 years old, so a ticking time bomb. Only thing that has saved it thus far is the previous owner was a little ol' lady that lived by herself and we have a 3 year pumping requirement in place by my local township. Now with 3 people in the house with 2 that can't grasp the idea of using less toilet paper I'm pumping it every year. No additives, wipes go in the trash can, and careful food cleanup there isn't much of a scum layer. The amount of paper in there though, oof. Replacement is around $35,000 as I can no longer go with a gravity drainfield and have to go with sand mound. Being a homeowner is great, but also frustrating.
Washlets/bidets have greatly reduce the amount of toilet paper used in our household
I use another product on that list (Bio-Clean) on a monthly preventative/maintenance basis to keep a drain pipe downstream from our kitchen sink clear. A section of the drain pipe would clog annually despite not rinsing food waste and grease down the sink. The clog looked like grease/fat on an endoscope and only an auger could clear it.
After doing this disgusting song and dance for the third time, I started using Bio-Clean and the drain pipe hasn't clogged in years.
Lipase and cellulase should work on fats/soaps and TPSo admittedly I didn't put much research into Bio-Clean prior to purchasing it - it was one of the few choices available here and seemed to have positive feedback from plumbers and users. Fortunately they do list the enzymes on their SDS:
Amylase - breaks down starches
Cellulase - breaks down cellulose
Lipase - breaks down fats
Protease - breaks down proteins
Non-pathogenic bacteria
I'm no chemist but it does seem specific to kitchen/food waste rather than soap, toilet paper, etc.
Roebic, on the other hand, only seems to contain bacteria cultures and no enzymes. For whatever that's worth
You will use the 3 seashells.You're not convincing anyone in my house (including myself) to use one of those contraptions. I know everyone raves about them, butt it's not for me![]()
Like nuking them from orbit, it's the only way to be sure.And the pumper$ seem to know that!!
Yes strong caustic will attack fat and protein should work pretty good.A gallon or so of fresh mix HOT 50/50 lye and water works on grease and about any other organic material in the drain pipes. Broke up a fatberg once with it.
Sitting in house with crabpy clogged collapsing line to street sewer gonna be $30000+ to fix
Waste is expensive human waste preciously so
Think about trying to keep 1200 gallons of waste water bacteria free. Impossible to do unless you dumped in gallons of Clorox every day. Even then it's a maybe. The newer engineered systems pump air into the system for 60 minutes so aerobic bacteria work and then stops for 60 minutes so anaerobic bacteria work. It's a much better system.
I think the leach field for the OP is done and a new one will be needed soon. It should never cause the water level in the tank to rise.
I don't think anything you pour into the system will help.
I am required to have my septic inspected 2x a year and it gets pumped when the inspection indicates pumping is needed.
