- Joined
- Dec 30, 2006
- Messages
- 29,558
It's all on the corporate level. They count literally everything.I have actually. But how in this circumstance? Who is monitoring a fricking Ford Quick Lane? The guys who run it aren't even paying attention!
I would think that Ford runs statistics on the likely success of the old engines using 20 weights, and compares it against their risk of costs--including reputation. They put this against the credits given to them in the retroactive re-grading. I can't see this being very risky.. worst thing might be abnormal ring wear..Can you tell me how many "CAFE credits" say FMC gets for back spec'ing older vehicles? I mean, really? Does the Guber'mint give Ford a check for filling your 1999 Crovwn Vic with 5W-20 instead of 5W-30? okaY.. I agree that might not be optimal and my first choice, but I think it's a bit silly to relegate everything to CAFE...
What vehicle?But what if you are driving a vehicle that was built prior to these "improvements" ?? Like 1998 that was "backspeced " too 5w20?
Both. Better engineering and much better lubricants. Rust kills more vehicles than mechanical problems and rust understanding and prevention has improved longevity.the vehicles are getting older despite thinner oils why is it that vehicles are getting older? better engines? better oils?
Well likewise I worked in the power generation industry for eight years or so both during college and afterwards, and have also spent the last 30 years in an aircraft maintenance environment. First for a 121 carrier and now with a 135 cargo carrier.Yes,
the gas turbine world is my world.
A funny story I’ve told a few times here. During Mobil 254 HTS (high thermal stability) testing, we had a large quantity of lightly used turbine engine oil. Danny (our shop helper) used it exclusively in his 2.8L Camaro. It was not quiet, but it worked and as far as I know there were no failures. It’s easy to dismiss this, but he was rough on his car and beat the snot out of it. Racing everyone.
That guy must have taken home a few hundred gallons of the stuff.
As you've effectively demonstrated it comes down to adequate MOFT. Yes a typical 20-grade oil provides sufficient film thickness for most engines under most operating conditions. Optimal for optimum fuel economy but there is no such thing as optimal for wear. Wear is reduced or controlled but there is never an optimal viscosity in that regard.As is a lack of basic automotive engine build knowledge. As in modern engines have things like oil coolers that may actually necessitate a (slightly) thinner oil to be optimal. There really isn't that much difference between a given 5W-20 or 5W-30. One relies more on polymers, one might have a thicker base oil to begin with. Guess which is which....
Based upon my 12 years here:If there were no opinion or emotion at play on this forum, then there would be no forum, because we would all just be buying by-the-spec Supertech and be done with it.
There is no such study. All the longest-lasting engines run SAE 0W-20 or SAE 0W-16, and none of them are thick-Euro-oil-running European engines.Before the switch to 20 wt oil there was a paper (pretty sure by SAE) that described shorter engine life of 20 wt as compared to 30 wt oil.
As I call the requirement was that the engine would last 200K miles. I recall that number got reduced to 150K miles. Wish I could resurect that information. It was around 2010.
"Everything"? Sure, but its not that silly to relegate this topic to CAFE.
I trust HPL's 20 weights. But not API blends.
It would make little to no difference. And on that commercial, are you sure the engines were under load? All of the “engine running without oil” commercials I’ve seen are unloaded engines. It is little more than a parlor trick.There was a tv commercial i think it was for synthetic castrol many years ago. They had 2 similar motors...one with dyno and the other synthetic. They ran them up to temp..drained the oil and restarted the motors to see which one ran longer without oil.
Would like to see a similar test using 20wt and 40wt and see which one runs longer before they set up...just for fun.
Slick 50, anyone?It would make little to no difference. And on that commercial, are you sure the engines were under load? All of the “engine running without oil” commercials I’ve seen are unloaded engines. It is little more than a parlor trick.
Slick 50, anyone?![]()
Hey now, I ran Slick 50 for one oil change back in the day. The engine didn’t blow up. Thus, Slick 50 is the best thing ever. 1000% success!![]()
