Originally Posted by Jimmy_Russells
S2000 (actually 9k)
I'll throw you a bone here and add in the other I4s Honda made with over 100 hp/L and redlines near or beyond 8k RPM. Si, Type R, etc.
Dang solid engines. Not quite bulletproof though. Very high oil consumption is common. The F2xC sometimes has rod bearing issues, oddly enough. Some of them have timing chain issues. All of them need valve adjustments, which the S65 doesn't.
Even ignoring that, being made by Honda and having such small displacements, they're almost exceptions that prove the rule for the kinds of engines we're talking about here.
RS4 Sedan
Less than 100 hp/L but we'll go with it.
This car was the poster child for DI deposit issues. Some examples fuel diluted badly enough to rip Motul 300V apart in like 3k miles. It helped put Renewable Lubricants, Inc. on the map for those reasons.
Lambo/Audi V10
Multiple Ferraris (granted they never see high mileage)
I'm assuming the parenthesis applies to both of these items. If so, you took the words right out of my mouth.
Lambo and Audi V10s also suffer from carbon deposits like other VAG DI cars.
People want to talk about revs and pistons speeds and blah blah, who cares if it is not long term reliable.
Barring abuse or extreme bad luck, the S65 will need rod bearings and throttle actuators like once in its life, and basically nothing else. So really, we could rephrase your rhetorical question as "who'd want to spend an extra $5k over 200,000 miles to have an 8400 RPM redline and razor-sharp throttle response?" I'm sure not everyone, but not no one, either.
S2000 (actually 9k)
RS4 Sedan
Lambo/Audi V10
