So the bottom line is that the highest wear seen during a cold start is in the ring land area and it is due to corrosion from the products of combustion. I guess my comments earlier (and relevant to this thread) were directed to the notion that thicker oil (higher film thickness) causes greater wear. In the absence of an antagonist such as wear particles, keeping parts separated and not allowing asperities to contact will prevent wear both at startup, warmup and operation. The higher wear seen during warm-up is again not due to the film thickness but this wait for additives to be activated.
Given the discussion in this thread and the other then more wear is seen during startup but not from the oil per se.
How much of the total wear in engine operation is due to this corrosion?
