Friction modifiers additives are only a small percent of the total oil
product and help the base oil do things that it otherwise could not...
Additives fall into several basic categories but Moly, Phosphors and
Zinc are the most often used friction modifiers... what ever small
percent of FM employed they will not defeat a wet clutch in good
working order...
JASO has approved 1,778 oils as of Dec 2023 which covers virtually
everything on the market... From 0w to mono grades... from 30 to 60
multi grades... from Auto to Cycle oils and yet no oil has ever been
listed by JASO for defeating a wet clutch... fact is high mileage not
our oil is the observed cause of a clutch loosing its grip...
If you wish high mileage clutch life then you have to invest in some
good old sweat equity... because at the first sign of slip it doesn't
automatically mean your clutch is tired and worn out or that your
clutch plates are wore too thin because you can Mic them to
determine serviceability and within the factory specifications...
Under scrutiny you'll find that your slip was due to normal
glazing and contaminates... if your interested in making your
clutch bite good as new then roll up your sleeves and read on...
Inspect the friction plates for glazing... make sure you have plenty
of material to work with... your shop manual states clutch thickness
in thousands of an inch or mm...
First removed the contaminants with Acetone... pick a hard surface to lay
over a 600 grit black dry emery paper... rotate the clutch plate in a
circle... you're just busting the glaze... don't get carried away
remove too much material... You should end up with a friction plate
looks dull like a new one as opposed to a shinny glazed one... recheck
thickness...
Next check the pressure plates for bluing caused by localized heat...
make sure they are not warped... consult the manual for a thickness
range... now removed the contaminants with Acetone and wire wheeled
them to erased the blue and also to generally scuff up the surface...
you should end up with a dull surface free of Blue marks...
