My point, as noted in the OP, was to discuss viscosity loss as it often gets blamed on shear and/or the wide visc spread, yet we are seeing it here on an oil with a much narrower spread and some searching will show T6 also going out of grade, the accidental AMSOIL example...etc. All of these being 5w-40's and going further out of grade that the 0w-40's usually do
If you say so.
But your OP's subject clearly called out PU 5w-40, and the first sentence of your post noted PU 5w-40 as having tremendous viscosity loss, and all your examples (minus the unintentional Amsoil one) also focused on PU 5w-40. So I interpreted it as you pointing to some inherent issue with PU 5w-40 specifically.
But of course, I am a PU 5w-40 user, so anything I say or do at this point will be perceived as me trying to defend it, so I'll shut up now and let others participate in the discussion.
The reason for the focus on PU 5w-40 was that it was a 5w-40 and currently the "hottest" competition to M1 0w-40 on the board IMHO. Yet it did, in a couple of examples, demonstrate some rather remarkable viscosity loss. This got me thinking about it and since that oil was the one I had found the examples of and I had them handy, I chose it for the subject and title
But I didn't want to keep the thread isolated to just PU Euro 5w-40, which was why I ended the post with:
Quote:
Now of course viscosity loss itself doesn't indicate an issue or that the product did not provide adequate protection and that's not the purpose of this thread, it is more to discuss causes of viscosity loss above and beyond fuel contamination as sometimes even the same model of engine will have very different viscosity loss than another fitted to a different vehicle.
Now that we've identified AMSOIL 5w-40 as also doing this, I would like to extend the discussion to all popular 5w-40's if possible and see if we have some more examples of dramatic viscosity loss (which I qualify as dropped down into the 10's or below) that are similar to the two PU 5w-40 examples I cited, the one that shows some decent fuel ingress, the other which suffered from significant heat soak.
If you say so.
