Going another hour, to 14, had dramatically bad effects on the two M1 oils, especially 0W-40. It has lost so much base oil that it has a wrinkled surface. M1 5W-40 has lost less base oil than M1 0W-40, but it does appear to be in worse shape than, in terms of consistency than D1 was at Hour 13. The two M1 oils have similar amounts of deposits on sides of the cups, though it is more evenly distributed with the 0W-40. Meanwhile, QS UD still looks like motor oil, it flows like oil, the deposit precursors (blobs) are moderate in quantity/size, and there deposits on the sides of the cup are much less than with the M1 oils.
Some points to summarize:
1. QS UD lasted significantly longer than the other three oils before deposit precursors formed.
2. QS UD formed less deposits on the cup side walls than the other oils.
3. Past tests of QS UD, which is API SN+, alongside QS UP API SP showed that the latter were significantly better in terms of oxidizing and resistance to forming deposits. This makes the results of M1 and D1 especially not impressive in a relative sense, since they were soundly beat by QS UD. A more accurate interpretation might be that M1 and D1 performed ok but not great and that these QS oils (QS UD and UP) are just very impressive. I think that is the more accurate statement, based on all of the past oxidation/deposit tests I’ve done. QS Euro 5W-40 API SP has also performed very well in this regard.
4. Rankings in terms of resistance to turning into grease-like consistency: QS UD >> M1 5W-40 > M1 0W-40 > D1 5W-40 ESP. This is also the same ranking in terms of lowest volatility, not surprisingly. However, the volatility is not the only factor. Chemical reactions occurred, some of which enlarged molecules, and others that split molecules. Those individually increased and decreased viscosity, but the net effect is generally a viscosity increase from heat-induced chemical reactions at these temperatures.
