JAG, thanks for all the hard work and for posting this. So other than using the oil grade recommendation in the owners manual, any other reason to not use VRP 5W-20 over VRP 0W-20?
I see that in addition to the 5W-20 having an apparent leg up in volatility, it also appears to have a slight bump in anti-wear additives from VOA results as noted below. My initial thoughts on that was that the 0W-20 has better base oils and thus required less anti-wear additives to reach similar performance levels for the two products. Am I missing something here?
VRP------------5W-20----0W-20
Calcium---------1033-------985
Magnesium------418-------156
Phosphorus------705-------673
Zinc--------------987--------888
Molybdenum----213-------156
Boron-----------134--------141
Cited:
https://bobistheoilguy.com/forums/threads/valvoline-restore-and-protect-5w20.381818/
