482 F is so hot that I would be very concerned that the oils would autoignite. In my one test when I had it too hot, VRP 5W-20 did do that. In the Noack test, there must be something about it that makes that not happen (oil/air ratio either too lean or too rich). My main testing focus is resistance to deposit formation rather than mimicking the Noack procedure as closely as possible.HOw did you pick that relatively low temp? I think ASTM D5800 tests at 250C. A question: how often will engine oil in use reach that temp (482°) to make that a reasonible standard?
Wait a minute. So now we're ok on BITOG adding up VOA data like PF to compare motor oils?JAG, thanks for all the hard work and for posting this. So other than using the oil grade recommendation in the owners manual, any other reason to not use VRP 5W-20 over VRP 0W-20?
I see that in addition to the 5W-20 having an apparent leg up in volatility, it also appears to have a slight bump in anti-wear additives from VOA results as noted below. My initial thoughts on that was that the 0W-20 has better base oils and thus required less anti-wear additives to reach similar performance levels for the two products. Am I missing something here?
VRP------------5W-20----0W-20
Calcium---------1033-------985
Magnesium------418-------156
Phosphorus------705-------673
Zinc--------------987--------888
Molybdenum----213-------156
Boron-----------134--------141
Cited: https://bobistheoilguy.com/forums/threads/valvoline-restore-and-protect-5w20.381818/
Listed on the NA website. I can it nowhere though.I have not tested those oils because I tend to avoid 5W-30 (and 0W-30) oils due to their relatively high VM concentrations, which comes with higher volatility than mixing 5W-20 and 10W-30 from the same product line. VRP and QS UP unfortunately are not available in 10W-30. I bought VRP solely for testing but that can get expensive if I do that for a lot of oils that I don’t intend to use in my engines.
