Originally Posted By: CR94
Originally Posted By: Gokhan
... Problem probably happens in neglected engines. My favorite is TGMO.
From reading numerous sad stories on priuschat.com and elsewhere, I get the impression the problem often occurs with non-neglected cars using TGMO. Son of Joe has explained in several threads why he suspects oils with high VII loading (probably including TGMO) are a factor.
Really? This is a ridiculous speculation.
First, it claims that the standard genuine Toyota oil used virtually for all new Toyota vehicles is destroying the Toyota engines. Can't you see how ridiculous this is?
Now, let's use some science instead of half-educated yet wild speculations. On BITOG, the problem becomes worse with self-claimed oil insiders, and people will take their "explanations" seriously, while often they are less worthy than any random info you can Google. There was even a self-claimed insider on the oil-filter thread who was trolling about the Purolator oil filters and he later admitted that he was making things up.
Here are the A_Harman indexes for Mobil 1 oils as well as TGMO. For TGMO I used both the MSDS and VOA data for KV40 and KV100. We don't have a data on HTHSV but 2.6 cP is the lowest possible value and that will put the A_Harman index as low as possible.
Code:
Oil Density KV40 KV100 KV150 HTHSV VI DV150 A_Harman index
M1 0W-20 0.841 44.80 8.70 3.91 2.70 177 2.91 0.928
M1 5W-20 0.852 49.80 8.90 3.89 2.75 160 2.93 0.938
M1 5W-30 0.855 61.70 11.00 4.75 3.10 172 3.59 0.862
M1 EP 0W-20 0.839 44.90 8.60 3.85 2.70 173 2.86 0.944
M1 EP 5W-20 0.850 49.60 8.90 3.90 2.75 161 2.93 0.937
M1 EP 5W-30 0.851 59.80 10.60 4.57 3.00 169 3.44 0.872
M1 HM 5W-20 0.856 50.00 8.60 3.72 2.70 150 2.82 0.958
M1 HM 5W-30 0.856 72.00 12.10 5.09 3.10 166 3.86 0.804
M1 AP 0W-20 0.840 45.69 8.70 3.89 2.60 172 2.89 0.899
M1 AP 5W-20 0.850 48.88 8.20 3.53 2.60 141 2.66 0.979
M1 AP 5W-30 0.851 63.33 11.70 5.09 3.00 183 3.83 0.783
TGMO 0W-20 SN VOA 0.851 36.10 8.50 4.09 2.60 225 3.08 0.844
TGMO 0W-20 SN MSDS 0.851 36.16 8.79 4.27 2.60 236 3.22 0.808
So, I guess the new Mobil 1 AP 5W-30 and the M1 HM 5W-30 would instantly kill the Prius engine because they possibly have even more VII than TGMO 0W-20 SN. And don't even think of running a cheaper synthetic or, God forbid, conventional oil in this extremely low-powered nonturbo engine that runs extremely clean.
And, yes, go ahead and blend your own oil as ExxonMobil has no idea on how to blend oil and, of course, mixing different chemicals don't result in occasional chemical reactions or different types of additives untested to be mixed together will still work after you mix them.
