- Joined
- Oct 21, 2023
- Messages
- 31
Thats a load of malarky the oil is just as clean out of the bottle.They addressed this in the video.
I think you missed one or two…A few previous threads on this oft-asked question:
https://bobistheoilguy.com/forums/threads/prefilling-oil-filters-necessary.334142/
https://bobistheoilguy.com/forums/threads/prefilling-oil-filters-not-good.114428/
https://bobistheoilguy.com/forums/threads/never-prefill-oil-filters.303920/
https://bobistheoilguy.com/forums/threads/do-you-fill-your-filter-before-installing-it.115456/
https://bobistheoilguy.com/forums/threads/learned-lesson-prefill-oil-filter.97287/
https://bobistheoilguy.com/forums/threads/do-you-fill-the-new-filter-w-oil-before-installing.25657/
https://bobistheoilguy.com/forums/t...bad-and-that-all-manufacturers-say-so.344934/
https://bobistheoilguy.com/forums/t...ght-about-not-filling-filter-with-oil.348541/
https://bobistheoilguy.com/forums/t...ur-oil-filters-before-installing-them.315262/
https://bobistheoilguy.com/forums/threads/do-you-prefill-prime-your-oil-filter.229597/
https://bobistheoilguy.com/forums/threads/mechanic-installed-filter-without-filling-with-oil.191615/
https://bobistheoilguy.com/forums/threads/filling-up-new-oil-filter-prior-to-installation.73492/
https://bobistheoilguy.com/forums/threads/pre-fill-diesel-oil-and-fuel-filters.262951/
https://bobistheoilguy.com/forums/threads/fill-oil-filter-at-every-oil-change.326379/
https://bobistheoilguy.com/forums/threads/plstell-me-what-you-know-about-filling-oil-filters.171295/
https://bobistheoilguy.com/forums/threads/any-advantage-to-prefill-filter.271960/
https://bobistheoilguy.com/forums/threads/how-many-people-here-prefill-their-filter.25280/
https://bobistheoilguy.com/forums/threads/pre-fill-filters.26256/
https://bobistheoilguy.com/forums/threads/what-do-you-all-mean-by-pre-filling.25560/
https://bobistheoilguy.com/forums/threads/u-dont-need-to-prefill-oil-filter-scotty-kilmer.267882/
https://bobistheoilguy.com/forums/threads/do-you-pre-fill-the-filter-with-oil-during-oc.155738/
https://bobistheoilguy.com/forums/threads/pre-fill-filter.63581/
https://bobistheoilguy.com/forums/threads/anyone-else-pre-soak-the-filter.325898/
https://bobistheoilguy.com/forums/threads/do-you-pre-fill-your-oil-filter.218523/
When I had a few samples run at TestOil, they did particle counts on the VOAs they ran. HPL filters their oil before putting into containers, and is also partly the reason they recommend buying as close to the quantity you will fully use without transferring to other containers- so you don’t contaminate it before use.The oil sample after the clean oil was circulated through the non-running engine should be dirtier because it would have picked up some old oil in the engine, especially in the smaller particle range that wouldn't be filtered well by the new filter (depending on the filter of course).
I would also think that new oil in bottles or jugs should be cleaner than oil out of a big bulk drum.
Data is support of pre-fill
There's a huge difference between added wear and blown-up/failed engines. People use the same arguement when talking about engine wear related to oil cleanliness from filtration or from the oil viscosity used. More engine wear over the long run typically won't result in engine failure, but a more worn engine can effect the overall mechanical condition and performance of the engine.The VAST majority of oil changes occur around the globe without pre-filling the filters, yet there is no corresponding report of massive numbers of failed engines due to this process.
I've measured how much oil it takes to fill a few medium sized oil filters, and it was around only 8-10 oz.Also a normal sized filter shouldn't even be a half quart.
