Hermann
Site Donor 2023
Another quart for that odd amount over 5 qts.
Anyone know the Conoco-Phillips date codes, or is this a Ford marking
You should have Supertech use you for a TV Commercial featuring the long life of your Craftsman mower engine on Supertech oil.One single solitary quart of Super Tech SAE 30 for my 24 year old Craftsman self propelled lawn mower. And a new spark plug and air filter FWIW.
That's the only oil that thing's ever had in it other than what it came filled with from the factory
I hope you cut these open and post pics. I'm curious to see what the magnets catchMy order of N42SH bar magnets and grade 26 Somarium Cobalt disc has arrived. Looking forward to trying these out in magnetic assisted filtration. Was way cheaper than getting a Filtermag which was overpriced IMO.
Really strong stuff, had to slide them off. Also accidentally chipped some of the samarium cobalt disc.
View attachment 210555View attachment 210556View attachment 210557
Will let ya know in a few thousand miles before i pull the filter. Just slap then on this morning.I hope you cut these open and post pics. I'm curious to see what the magnets catch
it’s still a type of oil. first transmission service of my built 4L80e. dave assured me that their ATF blue won’t shear out of grade like standard Dex III will.
pan drop/filter change takes roughly 3 gallons with my oversized pan, so i plan to do that then i’ll pump a gallon out through the cooler lines to flush the converter out.Nice, are you doing a drain and fill with the ATF or a full fluid exchange?
